ticking noise question
I hear it on the right side of the motor. And maybe ticking isn't the correct description. Its more like the sewing machine noise ppl describe. And yes I realize the M*'s might naturally make this type of noise, and mine did some at first, but after the FM map and work I had done, it was so quiet.
I also hear it at different times, but I assume that is due to the exhaust sound masking it. I can definitely hear it best when I'm cruising along at about 35 or 40 in 4th and let off the throttle completely.
But I hear it other times as well. At first I thought maybe it was something loose on my dash or fairing....it was hard to tell where the noise was coming from. But if I lean down toward the right side of the motor, I can hear that its coming from there.
I stopped by to talk to the SM at a local dealership yesterday...the one I spoke to a couple sat's ago, but he was busy with someone in his office so I left.
I think its still worth the labor charge for me to just have someone at least check the push rods and tighten/adjust them anyway if needed. Like I said, this motor
All my other Harleys had V&H pipes that put out a pretty throaty rumble. The ticks were probably there but were being drowned by exhaust noises. With my new TG sewing machine, little noises are less little now.
You really can't hear it at idle more. I do cause I know how it sounded before. But the best way to hear it is cruising at about 40 mph and let off the throttle. Very distinct sound then.
KSRoadKing
06-29-2013 07:39 PM
