Engine Noise Question
Old Nov 11, 2012 | 10:32 AM
Rfc's Avatar
Rfc
Default Engine Noise Question
Since I've installed the Dynojet Power Vision and open a/c I have noticed a tinking, tinging, pinging whatever you want to call it noise when rolling on the throttle. Thought it was my rattling gas cap but have ruled that out. Sounds like its coming from the front head but could be in the throttle body a/c area. Anybody know what this could be? Just remember tinking or pinging when accelerating fairly hard.
Old Nov 11, 2012 | 12:03 PM
rooti's Avatar
rooti
sounds to me like your map isn't exactly right
Old Nov 11, 2012 | 12:17 PM
RAWHIDE07's Avatar
RAWHIDE07
Possibly a lean condition but the stock ac&cover do mask a LOT of noise.
Old Nov 11, 2012 | 12:24 PM
2black1s's Avatar
2black1s
If the noise is truely pinging, and that's what it sounds like to me from your description, it's probably the result of some additional timing advance in your PV map.
I'm not familiar with the PV tables or how to adjust them so I can't help you there. My experience is with the PCV.
But if I were you I'd be looking at the timing tables.
Old Nov 11, 2012 | 12:29 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Yeah, that. ^
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Nov 11, 2012 | 12:42 PM
Shredding rubber's Avatar
Shredding rubber
If the timing is too far advanced octane will cure it. Find the highest octane possible,add a cup of xylene or toluene then listen to see if ping persists. If it does then the map needs adjusted,if it doesn't then the map needs adjusted. This method will just pinpoint the issue for you.
Old Nov 11, 2012 | 12:46 PM
maddghost's Avatar
maddghost
I agree with the timing tables remarks. It is hard to just take out timing without knowing exactly where the pining occurs, but it is however common with the PV. You shall have to learn how to use the software and it is complex at the start. If you bought it from fuel moto then Jamie will need three datalogs and he is quite good at tuning. If you got it from somewhere else and are on your own then call dynojet, it will take some time, but they will be able to help you and they have a number of good teks who will set you up right over the phone.
Also ther is a wealth of info on our own forums if you follow this thread :
https://www.hdforums.com/forum/elect...-by-admin.html
Old Nov 11, 2012 | 12:56 PM
Rfc's Avatar
Rfc
If you're talking about what rpm the ping occurs its in the upper end, I'd say it starts from about 3600 on. I did get the PV from Fuel Moto and I'm sure we will get it worked out, they are good folks.
Old Nov 11, 2012 | 01:02 PM
maddghost's Avatar
maddghost
Mine was the same - higher range. But I have cheated now and went and bought the dynojet autotune kit. It really kix azz!
get a few datalogs together for jamie as that is wht he will require from you in order to fine tune your timing tables.
nemick
Engine Mechanical Topics
Jul 18, 2014 07:49 AM
DarkMatter
Mar 19, 2012 12:26 AM
Stiffy
VRSC Models
Sep 7, 2010 09:51 PM
kelton3
Feb 11, 2009 12:02 AM
Stumpman
May 14, 2006 11:43 PM
