Hand switches
Old Aug 3, 2018 | 03:27 PM
$tonecold's Avatar
$tonecold
Originally Posted by Kyle Moore
I’ll try the lube thing. My bikes been modfied and stuff and I don’t wanna deal with them being *** holes about the warranty, I called and they said they don’t stock the switch which means I either go without my bike for a few days or make 2 trips and it’s an hour away from home. That’s irritating.
If the lube thing doesn’t work, order the lighted switch clusters. Installation isn’t tthat hard, the wiring unplugs from the switch clusters so you don’t have to pull wire or solder anything. Should be able to do it in about an hour.
Old Aug 3, 2018 | 03:41 PM
teedoff65's Avatar
teedoff65
Yup...switching out those things are very easy. I mean even I was able to remove them and reinstall them on several occasions. lol
Old Aug 3, 2018 | 04:03 PM
hollandhunter's Avatar
hollandhunter
Yes they are easy to replace just take your time once you get it unscrewed. The clips that snap together are plastic and i could see where a man could break them if he acted like a bull in a china shop trying to get them apart so you can unclamp it from your bars. Then use a flat head persision screw driver to unhook your wiring connectors. Just some tips i suggest i done it a few times. First time prolly took 20 minutes. An what ever you do dont yank on the wires to get them apart. Once the are unsnapped from the connectors they slide right out. You will know when they release. Several vids on you tube too.Then when you put them back together the clamp will snap/click back into place when you align it right without much force. Same thing with wire connectors. If you gotta get rough with either your doing it wrong. Be easy. Also would be a fine time to replace grips if you dont wanna do it again. I suggest taking a razor knife and cutting the oem grip off cause of the glue. Then the right side is a breaze. Controls take apart same as left. An you just slide the new grip on the tbw sensor and clamp your control houseing around the other end of it. Vids of this on youtube too that are good. Im not good at explaining stuff like that but the vids on youtube are on point front what i seen.
oh an if you do decide to jack with your controls yourself whatever you do dont tighten your master cylinder covers while yout at it. Unless of course there leaking or some nonsense. I found this out the hard way. I was jacking around with my last two bikes and ended up just snugging the master cylinder covers while i was there working snd guess what they both started leaking. There only suppose to be tighted down to a few inch pounds cant remember exactly but tightening them down to snug just by feel will mash the gasket and cause it to leak. An from my experience the only way to fix this is to replace the whole cover snd gaskey assembly and tightrn to manual spec. If the fluid gets on anything it will be a bad day. Sorry for the long post just like to help peeps when i can. I know very little but what i do know i dont mind to share.
Old Aug 3, 2018 | 04:32 PM
HDFBagR's Avatar
HDFBagR
Just had mine replaced by the dealer yesterday on a 2017 CVO Limited. Waited for it to be installed.
There have been two updates to this switch pac. The first update had an A after the part number
and the second update had a B after the part number.
There was one problem my dealer had during the install. Several months ago they reprogrammed
my cruise control and CB buttons with their Digital Tech so that the CB button is now on the left and
the cruise control button is on the right. The first problem was that I ended up with two cruise control
buttons when they replaced the switch pack. That was an easy fix, all they had to do was swap the
switch caps. The bigger problem was that the CB transmit and squelch did not work. They had to reprogram
the bike again with the Digital Tech to get it work again. So if have had them swap the two finctions
in the past, you will need to take it to the dealer to have the switch pack installed because it will need
reprogramming.
Old Aug 3, 2018 | 04:49 PM
Bumpandrun's Avatar
Bumpandrun
What happens when the switch lets go? First I heard of it from a couple Canadians other day. Loved there m8s with a ton of miles. But had clutch switch problems.......
Old Aug 3, 2018 | 05:00 PM
Fullbore55's Avatar
Fullbore55
With mine, I couldn’t start in gear with clutch pulled in. That wouldn’t bother me except that it indicated bad clutch sensor, which can result in unexpected behavior during low speed turns (like in a parking lot). So dealer ordered replacement and I brought it in following week for the install, which was done within 20 minutes.
Thanks to to others in this forum for alerting me to this issue!
Old Aug 3, 2018 | 05:05 PM
Kingglide549's Avatar
Kingglide549
What oh dear oh my does a clutch switch do...
I am almost too scared to ask....
I will bet it is Federally mandated nonsense and you don't need it!
Old Aug 3, 2018 | 05:12 PM
Fullbore55's Avatar
Fullbore55
Haha kg, you soo funny!
Old Aug 3, 2018 | 05:39 PM
Kingglide549
I bet its a safety switch so it will not start , right?
Just connect the wires together and be forever done with it.
Old Aug 3, 2018 | 06:23 PM
$tonecold's Avatar
$tonecold
It keeps the bike from starting in gear without the clutch pulled in. Good idea, although as weak as Harley starters are I can’t imagine it starting in gear and taking off. Seriously I can’t imagine that it would be that hard to design a switch that wouldn’t fail, but they’re probably made in Mexico or Asia. I don’t think there’s much electrical switch equipment made in the US anymore.
