Need help troubleshooting my bike regarding SE pro street tuner
I think the SE tuner is not going to be able to tune the aftermarket intake and exhaust combination you chose correctly. If you wanted to stay EPA/warranty compliant, you probably should have only done slipons with an intake of choice. I think those true duals need more adjustment than you are able to provide with the SE tuner. And this is likely where your issues are arising from.
Sorry I see that you said Power Duals not true duals, but my hypothesis still stands. That exhaust is flowing far more air that the stock header with slip-ons would be, and the SE tuner is having difficulty compensating for it.
matte (06-12-2019)
Spoke to my dealer. They said the M8s can bounce between 800 and 1000 rpms at idle and it is normal. Said the important thing is it is detecting the drop and preventing it from falling through and stalling. So far it has not stalled and it is not revving high like it was originally when I accidentally left the bracket on.
Plan is to check for a leak when I get home. If no leak, clean off the sensor and throttle body. Will probably check the sensor with a multi-meter. If all that is fine then I will leave it alone.
Spoke to Vance and Hines. They said the SE tuner is perfectly fine with their head pipes. Spoke to performance machine. They stated that if there is a fluctuation, there could be a leak and gave me a technique to see if there is a leak. I will test that when I get home from work tonight.
TriGeezer
10-02-2017 11:25 PM
itznin
05-19-2017 12:28 PM
