yeah, sure they put some thought and testing into it so it has merit, and the air cooled engines certainly warrant some attention in $tonecold's absolutely severe riding environment..but those ET temps even so, don't strike me as being a catastrophic failure waiting to happen, the engines have a protection mode and synthetic engine oil is developed exactly to handle those types of extreme temperatures
I agree completely, however I look at it as some small level of additional protection for those stuck in barely moving traffic. In any situation reducing extreme engine temps can only help the motor run better.
I agree completely, however I look at is as some small level of additional protection for those stuck in barely moving traffic. In any situation reducing extreme engine temps can only help the motor run better.
no doubt..and as I mentioned earlier..I was stopped in road construction in 107 temps for 15 minutes in Lewiston, ID, shut the bike down but I was close to heat stroke after riding in over 100 temps for 400 miles so my bike's well being was the last thing on my mind!
this was at the Pendleton, Or Rally, several hours before we got to Lewiston...I didn't look nearly as happy at the end of that day after almost going down from tar snakes and completely wiped out from the heat
This morning the ambient temperature was 77 F. I rode 17 miles on city streets at 50 mph. The ET held at 279 F until the last 3/4 mile, which was pulling into work at 25 mph. The temperature rose to 284 during that 3/4 mile distance.
I am showing lower temperatures than Steve, but the conditions are somewhat different. The speed limit is 45 mph here and the distance between stoplights is longer. Stopping seems to facilitate temperature rise. Also, I am using synthetic oil and I am not sure Steve was when he was monitoring temperatures.
The Mighty Mite type fans dont direct an air stream on the TwinCam head temperature sensor like a center mounted fan would and the TwinCams also have a tunnel behind the spark plugs to give air better access to the heads, so the TwinCams might actually have cooled better with that type of dual fans system. The amount of cooling the oil did in TwinCams was negligible though. Since the M8 is actually oil cooled I think the best way to bring ETs down is by cooling the oil better. This has already been proven by the differences in Steves readings between no fan and fan installed.
All My testing was done with regular HD dyno oil no syn. I found that the more stop and go the hotter it got, so low or slow speed is the killer. Once you got above 45 mph things started to cool down and yes, LA has many more traffic lights than where your at but were full up and your just getting started over there, give it a few more years and it's going to be just as bad for traffic as it is here. We have a lot of 25 - 35 mph speed limits here in town and at those speeds it just kept getting hotter. As for the Twin Cam temp. sensor it is located very close to any of those type fans where the M8 now has it completely out of the air stream created by those fans, so its going to give you a much better representation of what is really happening. I'm all for cooling, so anything that helps is a good deal in my book but my point was the Twin Cam reading showed much better than what was really happening.
I can see what youre saying with the fans on the TwinCams. My ETs would run about 270 F on the highway. When I would get off the highway and come to a stop in town my ET would drop about 20 degrees. So thinking about it, the fans were probably cooling the sensor way more than they were actually cooling the head. Jason had a bike fitted with extra sensors and he did a lot of research on how well his fans worked. Unfortunately, when he took down his website that was lost, at least I dont have it.
What are you using to record the engine temps? I assume it's taking data from the ECU and the temp sensor on the rear cylinder. I'm using a Power Vision and I'm seeing average temps in the 320- 350 range. 17 RGS, lower fairings, stage 1 AC, stock head pipe and Jackpot slip ons. I checked with Fuel Moto and DynoJet and the temps I'm seeing are average according to both.
Neil
RDMC
Yes I am reading the ECU with a PowerVision. I do have the fan kit on my oil cooler. If you look at Steves testing, the fan made about a 50 F difference.
