Why don't the nuts that hold the pipe flanges to the heads use a lock washer? Also, they did not have Loctite. By feel, they were about a 10 ft pounds of torque. Not real tight. 3/8 ratchet took no effort in removing.
And then, what do you do when you replace your pipes? Do you add lock washers or use Loctite? Or just use those simpleton nut/washers that came on the bike? There is plenty of bolt space to add a lock washer....
2020 LRS.
Reason: added model
I pulled the exhaust system off a couple times (stock 2018 RGU) to do other things that I needed more room for, such as working on the clutch slave, or cleaning and lubricating the foot brake pedal. Gotta remove the headers.
Here's what I learned about the headers going in to the heads. Don't worry about lock washers. They apparently are not needed. Don't bother replacing the exhaust gaskets, unless they are bunged up, which they shouldn't be. Make sure the headers go straight into the heads, and keep checking as you snug up the nuts. Snug them to spec, as explained in the service manual. Put everything else back on (tighten clamps in stages front to rear), and take the bike out for a nice long ride, checking for leaks along the way. Should have no "backfiring" or decel popping. Let the bike cool down overnight, and recheck the header nut torque. They almost surely will need more torque.
If you do end up replacing the gaskets, it is a weird job compared to other bikes I've seen. Takes a "special tool" but you can get it done by hand. Best not to replace, they appear to be useable for many cycles.
2020 LRS.
You will never see a split lock washer on an exhaust system. The heat will make it a useless washer, and the nut will fall off. I have seen some "wave" washers on import diesel exhaust manifolds over the years that actually retained tension, and shape, but a properly torqued nut on a hardened flat washer, with a small dab of anti-seize is the way to go.
I've seen some who double up the nuts. I've never, nor have I had one go loose. Torque on install, check/torque again after a couple hours run time is all they need.
