Milwaukee 8 Coil Differences
I checked, and the wiring is the same between Softail and Touring going to and from the ECM/BCM and Ignition Coil. On Paper it should work but who knows...
Dug this up: " Ignition coil DTCs sets if the ignition coil primary voltage is out of range. This could occur if there is an open coil or loss of power to the coil. If front and rear DTCs are set simultaneously, it is likely a coil power failure or a coil failure. "
I'm puzzled now, if they are both M8 107s just different frames what would possibly be different between the ignitions. The bike starts, runs, even revs up just cuts off after and doesn't start again unless you cycle the ign.
It seems it’s wiring at the coils, BWTFDIK?
Bob
It is possible the top rocker cover spark plug boots didnt seat correctly as I didnt get a positive click on those like I did the factory boots, which would be also front and rear faults but I didnt have a spare set to try, I also dont know if those would throw the same codes.
I suppose it is possible to not have the plug wires seated fully and thus the problem not being the coil but the installation.
Maybe the spark plug wires are different since most of the touring models have some kind of radio or infotainment system. An increased resistance of spark plug wires required for touring may require a coil with a higher output? Pure speculation with no factual basis though.
I wonder if I has something to do with center spark plug vs outboard spark plug and where they are connected to the coil?
Set the Softail coil and the touring coil side by side then use an ohm meter to compare readings between the two. That might tell you something.
All that being said, I am shaking my head at this conversation and why anyone would do this. Lets go ahead and fix a perfectly running motorcycle until it doesnt run and then try to figure out why it no longer runs.
FWIW, on older carbureted bikes, It didnt much care, as long as there was a spark. Dual fire meant it didnt matter how the front and rear spark plug wires were plugged in and was actually a troubleshooting tool.
