Engine Temp
I installed fan assisted oil cooler, but as I see it does not help to keep engine cooler.
I have FP3 and monitoring engine temperature.
At idle temp raised up to 332f(167c). When I checked engine head temp by temp gun, front was about 332f(167c) and rear 275f (135c) and FP3 was showing 332f(167c) - front cylinder temp. I have enabled EITMS.
How could it be , as I know only rear cylinder has temp sensor ?
Oil radiator temp was around 154f(68c), its good, but its seems fan only cools oil, not engine.
Conditions:
Ambient temperature during testing low - mid 70's
In Town riding with little traffic but normal stop lights
Speed limited to posted speed limits (35 - 45 mph)
Before Upgrade Results:
Measured Peak Engine temperature = 340 F
Measured Peak Oil Sump temperature = 267 F
Measured Peak Head Oil Return temperature = 290 F
After Upgrade Results:
Measured Peak Engine temperature = 302 F
Measured Peak Oil Sump temperature = 201 F
Measured Peak Head Oil Return temperature = 240 F
Think 270 is enough for normal operating engine.
