If you have a warranty and want to keep it then the HD product is for you.
If all your ever going to do is what you have now, it's a toss up.
If your plans are to go bigger with a cam and such then an aftermarket tuner like Mastertune or PV is the way to go.
He de-catted the head pipe already......what warranty?
So, what are you trying to do? More HP? More Torque? Better red light drags or better 2 up touring? Just going an getting pipes, intake and a tune without knowing what you want to do.......
I don't mind that street cannon 4.5 mufflers i think they are made by Vance and Hines.I also read that the M8 is a pretty decent head pipe.I am just wondering about the dyno jet canned map how it performs over the EPA harley map
If you purchase from Fuel Moto they provide a map with tailored for what you have done to the bike and support when you change it. Power vision support fro fuel moto is out standing.
Well will be doing the cams after warranty is up and bud had a stock head pipe with cat if i need it for warranty claim which hopefully wont need.After warranty is up will do cam but waiting as i don't want a SE cam now
I think with SEPST you can adjust AF ratio at any or all RPM and speed settings and make it more rich than you want. Is that incorrect?
incorrect is my understanding..and the whole point of it having its limited capability is to make sure it can't operate outside of EPA parameters / standards
My understanding was that the New SE tuner released after the 2017 EPA decree only changes the timing. It does not change the fuel air ratio like the previous SE race tuner did. I could be wrong but this is what i remember.
I have one, bot in 2018, and used it to enriches AF after downloading, for both stage 1 and stage 2 upgrades.
I certainly dont run lean with freer flowing AC and exhaust. If anything, Im a bit rich.
