Screamin Eagle tuner question
Old Oct 19, 2020 | 07:17 PM
Gizmo83's Avatar
Gizmo83
Default Screamin Eagle tuner question
Had the dealer install the SE tuner along with the Heavy Breather Elite intake. I'm going to swap the Elite for the standard SE wedge air cleaner. My question is will this require a different map install from the dealer? Is that even how that works with this tuner? Can I just swap the intakes and not worry about the tuner?
Old Oct 19, 2020 | 07:24 PM
MikeySom's Avatar
MikeySom
Why not just call the dealer that installed your tuner and ask.
Old Oct 19, 2020 | 07:25 PM
Gizmo83's Avatar
Gizmo83
Thanks for your help, pal. Very insightful. We all know the dealer is the best place to ask for advice.
Old Oct 19, 2020 | 07:43 PM
cbrenthus's Avatar
cbrenthus
If you aren't changing exhaust, you really don't need a tune. And from what I've heard, I think the SE tuner does not adjust the fuel, only timing due to EPA regs. But, since you have it, I would say that no, you don't need a new tune for a different air cleaner.
Steve Cole's Avatar
Steve Cole
HD EFI Guru
If your bike is all stock other than the air filter and you are switching to another air filter you will be fine.
Old Oct 19, 2020 | 07:44 PM
Cogito's Avatar
Cogito
You don't need to update the tune for AC change.
There is only one map per stage in the street tuner, so if you change your AC there is no different map for it.
Old Oct 19, 2020 | 08:27 PM
Gizmo83's Avatar
Gizmo83
All stock other than a set of S&S slip ons and the AC. Thank you.
Thank you, that is what I needed to know.
Old Oct 19, 2020 | 08:41 PM
TriGeezer's Avatar
TriGeezer
Old Oct 20, 2020 | 03:06 AM
FatBob2018's Avatar
FatBob2018
Note, you do have the option of running some auto-tune SmartTune sessions with the SE tuner, which may help it deliver a more accurate tune for your particular equipment. Might help some.
Old Oct 20, 2020 | 06:00 AM
mjwebb's Avatar
mjwebb
definitely..poor man's dyno tuning...I had my 107 dyno tuned with it because we have a great performance team at our dealership, and it is the preferred method in the SEPST tutorial but auto tune sessions can't help but improve upon the base calibrations..was just too tedious and time consuming for me, and I didn't have a laptop or the VCI cable...my bike yielded some gains and ran fantastic for 39000 miles before trading in
