Show me your tool combo for p clamp exhaust bolt
#31
Thanks Jamie, appreciate that. Apparently my 1/2" open ended wrench is much bigger than what you are using. Your method with the 1/4" drive wobbly is exactly what I was thinking as I have used the 1/4" drive socket without the wobbly with the heat shield moved out the of the way and the painters tape, but I felt a wobbly would make it a little bit simpler. Just got back from the hardware store and didn't even think about the 1/4' drive wobbly. It's funny as people are showing me pics of a straight shot to the nut on their bike. Yeah, that's how it was initially. One more thing, don't cut the zip tie on the p clamp with the RTX until after the nut is secured down a bit. Initially I left it on, then when I loosened the nut to reposition the pipe I thought that I should clip it. I then realized taht it is there to hold the clamp together while you are sliding it over the threaded shaft. Lesson learned once again.
One more thing Jamie, I want to confirm that the gaskets that the RTX uses are jsut plain EVO gaskets?
#33
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#35
txphatboy
12-07-2012 01:03 PM
