How much power are you putting down on stock bottom end
Old Jan 29, 2021 | 09:45 AM
Chef232's Avatar
Chef232
Originally Posted by Ridetothehill
If you've got your cases split, now would be the time to upgrade crankshaft.
Not in the budget at this time and it's already put back together. After starting this thread I decided the crank would be ok for the power I'm after. Don't plan to go north of 160/170. Crank work was quoted around $800 plus shipping and a month turn around time. If it blows up later than so be it. I could have done it but then I wouldn't have been able to afford the bigbore kit with the other goodies I need which would make the work useless. They'd balance, true, weld, and pin for the bigger pistons that I couldn't afford with the work so it didn't make sense. Hearing from other members making big numbers on their stock cranks I'm not too worried about it.
Old Jan 29, 2021 | 09:56 AM
Ridetothehill's Avatar
Ridetothehill
For another $800. you could have got a Dark Horse crank. Just the other day I saw a broken stock crank at my dealers machine shop. The shaft was completely sheared off at the output side. It had previously been welded. It happened in 4th gear on a 124" build. If I were starting a performance build today. I would start at the bottom.
Old Jan 29, 2021 | 10:24 AM
Chef232's Avatar
Chef232
To each their own, I think that money is better spent on a compensator sprocket and billet clutch basket which are known failure points on the M8. If I was planning a more aggressive build I would have bit the bullet and got the work done and waited till I had the money for the bigbore install. That very well could have put my bike down for the upcoming season which is not something I want to do. The past few months I've already dropped over 3k into it. I'm pretty much tapped for a season or two. Might do heads and TB next winter or the winter after, will just have to see if I want more power or if I'll be happy with what I've built.
Old Mar 27, 2026 | 03:32 PM
Grant_18FLFB's Avatar
Grant_18FLFB
Stage I
Looking to see how much power everyone is putting on their stock bottom ends with a big bore kit . Looking at a 124 kit and possibly heads and a tb later on. How many miles have you put on your setup? At what point should one start looking at darkhorse for welding, pining, balancing, and truing? How long is the life expectancy of main bearing?
Sorry Im soo late to the party.
I just rebuilt my 107 to a 124 using a Fuel Moto big bore kit and more 》10.75:1 Compression, CP Carillo Pistons, S&S under piston oiler nozzles, Woods 22XE Cam, S&S Oil Pump + Cam Plate + Lifters + Roller Rocker arms, Fueling 1 piece pushrods and 6.1g/s Injectors, OEM heads with OEM Valves second hand from a wrecked milwaukee 8 bike with 5600 miles on them, HD SE Plug Wires, Drag Specialties Iridium Plugs, Arlen Ness enhanced (+ size) air filter for HD OEM Air Cleaner housing (Oval - Chrome from a 114 edition Milwaukee 8), Revolution Performance 55mm M8 Intake Manifold, SPAL Radiator Fan mounted to the Oil Cooler with a simple on/off toggle, Dynojet Power Vision and Wideband O2 "target tune kit"
I am just starting the Thermal Cycle process to seat the Rings, I have an Appt for Dynotuning in a couple weeks.
Sportylee
Apr 20, 2016 08:12 AM
cpbedor
EVO
May 29, 2013 11:34 AM
bikenut1957
Jan 12, 2011 11:46 PM
leohd
Jan 13, 2009 06:49 AM
Tx_Outlaw
Exhaust System Topics
Dec 18, 2005 04:50 PM
