While Installing SE Manifold.....
Old Mar 22, 2021 | 11:54 AM
702's Avatar
702
Default While Installing SE Manifold.....
I find this. The flange bolts were tight, but I could easily rotate the manifold by hand. Rear manifold seal leaking oil. I did the bypass not long ago, so this is probably residual - but still - that's quite a bit isn't it?
Something else going on here that I'm missing?
Old Mar 22, 2021 | 03:05 PM
manofsteele2003's Avatar
manofsteele2003
Pretty nasty. How many miles do you have on it?
Old Mar 22, 2021 | 03:12 PM
702's Avatar
702
Just shy of 27k.
Old Mar 22, 2021 | 03:14 PM
702's Avatar
702
When I finished the manifold swap I installed the updated HD Stage 2 tune, then went for a quick 15 mile ride to get it hot, then check for any leaks etc.
Sure runs better.
Old Mar 22, 2021 | 05:28 PM
Hairy Larry's Avatar
Hairy Larry
Big Kahuna HDF Member
My manifold looked the same. This happened before you did the breather bypass. I'm sure your new manifold will stay clean.
Old Mar 22, 2021 | 06:02 PM
702's Avatar
702
Makes you wonder why so many are anti-bypass doesn't it?
Old Mar 22, 2021 | 06:27 PM
Hairy Larry
I guess they believe this is acceptable.
Char84
Jul 30, 2020 08:23 PM
Godinaz
Milwaukee Eight (M8)
Feb 15, 2020 03:46 PM
Kyle Moore
14
Feb 2, 2020 02:25 PM
icebite1
17
Sep 4, 2013 03:10 PM
UofM_fanatic
Screamin Eagle CVO Models
Jan 31, 2008 06:46 PM
