Been a while. Question
Old Sep 21, 2021 | 06:37 PM
Dark lo's Avatar
Dark lo
Default Been a while. Question
What up good ppl. It’s been a while.
so I have a 21SGS that I bought in June of this yr. over the last month I haven’t rode as much as I want do to work so my bike sits for a week at a time. I noticed that both tires have lost pressure. This should not happen if it sits for a week or two! Anyone else having this issue with the 2021?
Old Sep 21, 2021 | 06:45 PM
MURPHCC1's Avatar
MURPHCC1
so I guess you're still under warranty.......bring it back and let them fix it.........
Old Sep 21, 2021 | 06:46 PM
mjwebb's Avatar
mjwebb
I'm on my 3rd set of tires on my 2020 with TPMS..they have always stayed put, aside from the normal pound or two in big ambient temp changes..TPMS has worked consistently well..no issues with tire pressure whatsoever
Old Sep 21, 2021 | 07:05 PM
702's Avatar
702
You might try tightening the valve cores a bit and see if that helps.
Old Sep 21, 2021 | 07:47 PM
Red's Avatar
Red
Aren't the temps dropping up there? Ten degree drop is probably good for a couple pound air loss. No psi issues with my '21 Limited
Old Sep 21, 2021 | 09:59 PM
Dark lo's Avatar
Dark lo
yes but it’s happen when it was in the 80’s also
Old Sep 21, 2021 | 10:00 PM
Dark lo's Avatar
Dark lo
will try it. Thank you
Dark lo's Avatar
Dark lo
definitely will consider that if I can’t find a solution
Old Sep 21, 2021 | 10:13 PM
mjwebb's Avatar
mjwebb
the valve core tightening idea from 702 is a great idea..also, one thing to remember is don't rely on TPMS as an accurate 'gauge' (pun intended' for psi..it can be off a little from using a high quality tire pressure gauge
Old Sep 22, 2021 | 07:04 AM
skratch's Avatar
skratch
how much pressure are we talking about? i find that my pressure will vary a lb or two after sitting for a while also.
at least you're checking your pressure regularly. that's more than some folks do.
