wheel bearings
Old Jul 5, 2022 | 09:57 AM
DGLIDE20's Avatar
DGLIDE20
Veteran: Canadian Forces
Every third tire change I change the bearings, cheap insurance to avoid a problem on the road.
Old Jul 5, 2022 | 08:55 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by Andy from Sandy
With the wheel off the floor grasp it top and bottom. With a very forceful push pull motion can you feel any play at all? If not the bearings are still good.
A lttle play is OK a new bearing has about 0.005 axial. What's more important is while pushing do you feel any roughness.
Old Jul 5, 2022 | 09:03 PM
TwiZted Biker's Avatar
TwiZted Biker
With the crap china bearings the moco uses stock they'll get changed when the tire does. Extra expense is cheap compared.
Old Jul 6, 2022 | 02:34 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
A little play is OK a new bearing has about 0.005 axial. What's more important is while pushing do you feel any roughness.
A little end play is okay, so I was wrong, but 0.005" is greater than HD is expecting from their bearings. Sportster FSM
9. Check wheel bearing end play.
a. Mount a magnetic base dial indicator on the brake
disc. Set the indicator contact point on the end of the
axle.
b. Move the wheel back as far as it will go. Holding the
wheel in position, zero the dial indicator gauge.
c. Move the wheel forward as far as it will go. Note the
reading of the dial indicator. The lateral movement or
end play must be less than 0.002 in. (0.05 mm).
Repeat the procedure to verify the reading.
d. If end play is 0.002 in. (0.05 mm) or more, remove
wheel and replace both wheel bearings.
Old Jul 6, 2022 | 09:46 AM
Max Headflow
You win I got the tolerance off (if the manual is correct for 6205). Still if the bearing race / ***** start to Brinell or Fret, that tolerance won't show any issue. In fact it will tighten up. It may be hard to stay under as radial clearance on a C3 bearing will be about 0.0013".
IMO the biggest issues with 6205 bearing dying are improper installation and contamination. The many of the aftermarket installers ar designed wrong. They put a high axial load on the bearing by pressing the outer race in too far.
jmn1960
Jan 22, 2014 01:47 PM
gvallanc
Sep 23, 2011 06:53 PM
cameraboy
Sep 10, 2011 12:55 AM
Professor
Aug 16, 2008 06:48 PM
FLAMED96
Dec 27, 2006 01:27 AM
