Clutch Replacement
Old Aug 27, 2022 | 01:35 PM
$tonecold's Avatar
$tonecold
Originally Posted by 702
Decision made. Trask Basket ordered, and will go get (or order) the HD 37000258 clutch kit and the 1275 springs today.
I've got the 10 plate clutch with less than 1000 miles on it. Took it out to install a Rekluse TorqDrive. Showing $236.32 on Suburban for it. Surdyke has it for $214. I'll let it go for $150 shipped. PM me if you want it.
Old Aug 27, 2022 | 04:10 PM
702's Avatar
702
Thanks but I bought a new set already.
Old Aug 27, 2022 | 05:22 PM
1badharley's Avatar
1badharley
Rekluse TorqDrive.....very nice! Did not know that the stockers used alum instead of steel on the plates....as mine is starting to make a weird squeaking noise when hot......thanks for the info!
Old Aug 29, 2022 | 11:26 AM
jake24lt's Avatar
jake24lt
The Rekluse torque drive, has some nice steel sleeves for the clutch basket that keep the plates from chewing up the slots in the basket. Also, makes for a smoother clutch.
Old Aug 29, 2022 | 11:34 AM
NorthWestern's Avatar
NorthWestern
I was not aware of this! I went with the Evolution Industries basket, and I wanted to install this clutch pack next time, and go back to regular pressure springs. I assume there would be no issue with those shims/sleeves on the aftermarket basket?
Old Aug 29, 2022 | 12:23 PM
jake24lt's Avatar
jake24lt
The tabs for the rekluse clutch plates are slightly narrower than OEM to accommodate the space used by the sleeves.But the setup is made for the stock basket dimensions. The Trask basket, which I have, works great. I am sure the EI basket would be the
same, as you can use stock style clutch plates in it.
Old Aug 29, 2022 | 03:19 PM
1badharley's Avatar
1badharley
I know what I will be doing this winter......
Old Aug 29, 2022 | 04:04 PM
1badharley's Avatar
1badharley
Oh what the H*ll.....just ordered one
Thanks guys!
Old Aug 29, 2022 | 04:51 PM
702's Avatar
702
Thanks guys!
This Forum sucks doesn't it?
Old Aug 31, 2022 | 11:00 AM
FunHuman's Avatar
FunHuman
And with a Trask basket I will be worry free for a while, LOL!
1275 springs, Trask basket great setup. I used Carbonite G3 discs only because I thought I needed to swap out my HD SE discs when I increased HP.
I definitely did not need to, the SE stuff is fine with the 1275 springs. Got sucked into the spending spree.
SE discs now sitting in oil for when they are needed.
Enjoy.
