My point was simply after 6 model years now and countless posts about cam upgrade it is never mentioned, referred to, recommended or on parts lists from owners, until now…we can all agree that if it was a problematic part it would have been reported here as nauseum. Bearings, lifters, cuffs, etc. but never mention of sprocket
First I mean no offense to you. I don't post here nearly as much as you do. I've been building Harleys for quite a a few years, but surely don't know as much as some other guys. I'm always learning, and I come here to see what's new. Over the years I've become friends with some of the best Harley engine guys in my area. I've learned plenty from them. On the occasion that I read about something here that I haven't heard of before, I don't post anything. I read posts from guys who have experienced that particular issue. I'm not looking for opinions from those who haven't dealt with that issue. What can I learn from that? I'm looking for facts and this is a valuable resource for that. Again, I mean no offense to you, and you certainly have the right to your opinion, and your right. This is not a major issue that will leave us stranded somewhere. It's just something that is wise to replace if you change cams to gain performance. These sprockets will just give you more accurate cam timing!
sure, no big deal..I was just trying to offer thoughts on OP's comments he asked for
"wondering if this is really worth $60. Any thoughts on if this is a good preventative measure purchase or just another non essential item to take my money."
can't define worth because like most of the available replacement parts that's relative and subjective
and regarding his comment "Any thoughts on if this is a good preventative measure purchase"
assumed "preventative measure" usually refers to avoid a potential problem, in which case I stated that the OEM part has no history of being one reported here since the M8 inception
but hey, if it takes up the play / slack which solves a shortcoming of the OEM sprocket not performing properly then it's a good thing..if the OEM performs its duty properly then I'd rather spend the money elsewhere
If you have been silently following this forum I doubt you are surprised, it's a common occurrence.
I have read about this issue and I'm glad Old Mike provided a pic. I say don't let the opportunity pass to make an improvement when you are in the cam chest esp when it's $60 your considering. I imagine you will be replacing other inferior parts, inner bearing, lifters and cuffs.
It does happen. It's very rare ( 4 in 10 years) , but I have had to replace flywheels because the machined flat had become a curve. 1 had broken the retaining bolt, so I expect that damage came from the sprocket losing it's support. Pretty obvious rattle. The other 3 all had a lifter tick sound, coming from the cam cavity, that went away above idle.
