BCM sync for 2022 models
Old Nov 25, 2022 | 01:18 PM
MRFREEZE57's Avatar
MRFREEZE57
Originally Posted by d_slat
Wiring it in series won't work, you would have to wire it in parallel with the led.
You are correct, my mistake, series would increase resistance and make the issue worse.
Old Nov 25, 2022 | 06:09 PM
d_slat's Avatar
d_slat
Originally Posted by Andy from Sandy
In the other threads I have read the only problem is with the dash light and nothing else.
With reference to a wiring diagram each turn signal is powered by its own wire from the BCM. The indicator on the dash is a CAN bus command to the speedo and the speedo sends the power to the indicator or repeater light.
So after the BCM has done its thing for LED turn signals a problem exists with the repeaters.
my guess, it's not that simple. The bcm probably thinks there's something wrong with at least one of the turn signals and is telling the speedo to fast flash the dash indicators.
Old Nov 25, 2022 | 10:25 PM
rideonva's Avatar
rideonva
I’d guess the problem is only with aftermarket. I’ve put H-D LEDs front and back on my 22 RG and BCM learned just fine.
Old Nov 25, 2022 | 10:32 PM
mjwebb's Avatar
mjwebb
Old Nov 26, 2022 | 08:37 AM
shore's Avatar
shore
never seen those?
Old Nov 26, 2022 | 09:56 AM
MRFREEZE57's Avatar
MRFREEZE57
Tested a standard lamp yesterday from the OEM signal, is around 1 ohm, am guessing the HD LED signals use a resistor to balance the load.
Old Nov 26, 2022 | 10:05 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
A turn signal incandescent bulb is around 21W. Its resistance would be around 7 ohms.
Old Nov 26, 2022 | 11:59 AM
mjwebb's Avatar
mjwebb
Originally Posted by shore
never seen those?
they work great, look great and holding up well since introduced in 2018
https://www.harley-davidson.com/us/e...rts/p/67801148
https://www.harley-davidson.com/us/e...rts/p/67801150
Old Nov 26, 2022 | 02:32 PM
Redrodyankneck's Avatar
Redrodyankneck
Checked out the link and in the 1st review someone said they were 3 times brighter than custom dynamics, hard to believe cause CDs are very bright.. I was going with HogWorkz because of the sequential feature which is pretty cool. I can't live with the hyper flash dash lights so I'll try the HD inserts.
Old Nov 26, 2022 | 02:51 PM
mjwebb's Avatar
mjwebb
reviews....how did they measure 3 time brighter?..LOL...CD, as folks know, have a great following and warranty, lots of happy customers..I have friends using them..one set failed but were replaced for free no questions asked...but I bet you will really like the HD ones..they are really bright and only a one year warranty but LEDs in general are long lasting and mine have been fine for at least a couple years now..if after a few years one goes out...well, $125 bucks for more years ain't going to break the bank...and most importantly perhaps, the swap should be seamless and transparent in operation
edit: noticed the below in HD online instructions in the Details section of the linked page ..wasn't necessary for my 2020 but like it says..if needed follow the procedure
"After installation of new turn signal inserts, verify proper operation. If turn signals appear to flash quickly, BCM will need to "learn" the new current setting of LED inserts. To put BCM in this "learn" mode, flash hazards for 30 seconds. Then turn hazards off and recheck flash rate of turn signals."
