You engine needs 91 regardless of it is 10% blend or not. The reason it needs the higher octane is compression. Has nothing to do with better fuels. Lower octane will detonate under compression and heat before spark .
My 1996 FB has sat in the cold garage all winter as it has done all of it life. It is a lower compression engine and runs 87 octane. It has pretty much always used 87 10% blend. It has never had the carb apart. It will start right .up tomorrow or next week if I choose.
I never go out of my way to get non blend gas.
Thought I post this question here since it's not really specific to any bike. I don't believe the ethanol in most fuels (10%) around here will hurt the engine, but we do have a few stations near me that sell non-ethanol fuel, but only in mid grade (87 octane here, sometimes 88 if you get lucky). The question is, would there be any benefit to running the non-ethanol 87 and some octane boost vs just running the premium from the pump with the ethanol in it? I am referencing performance and longevity, NOT cost.
Note, I have not tried this yet. Just sort of thinking out loud. Thoughts?
I should also note that I have been running this 87 ethanol free in my trucks for while now and I do see a small fuel economy increase.
Been running 10% ethanol since the 80s. Hurts nothing. It actually keeps water out of the bottom of tanks. Hurts nothing and I use to work on everything gas ran. As long as the tank is sealed, it is fine for 6 months on a EFI. Now a carb if you don't drain it will dry up and even nonethanol will gum up jets. Oil mix 2 strokes is no different. In a 25 Yamaha, it will stop up the jets in one drying. However, it has bleeder screws on the bottom of the bowls. All you do is break them loose. Then snug. The threads have a groove in them just for that. If you screw them out, you would have to pull carbs to get them started because your hand won't fit. A long screwdriver will.
In 40 years I have only put pump gas in
Its been a long time since non-ethanol has been available
And for the most part I have only used stabilizer the past few years
Bought the Harley last year, so will uses stabilizer from now on
It's interesting, in the NW, and even at our higher elevation towns, all of the non-eth gas is higher octane. Typically found at our Conoco stations. We have the race fuel stations scattered few and far between as weill.
I try to put non-eth in whenever I can, just a habit on bikes. I treat them like my power equipment still, for some reason. It's all I buy for the home gas cans for generators, saws, etc..
I know it isn't an issue, just a habit. When I leave my area of the world, I certainly don't wring my hands over it, and just look for the best gas available. Finding that is hard enough in some of the backwater "towns" we have found ourselves in down in other parts of this country, and I have run many-a-tank of some suspect fuel though this bike without issue LOL
I put whatever 91+ octane gas is available in anything I got, bike/mower/weed eater/tiller and never had an issue with storage or operation. Some people think that ethanol will destroy an engine, endorse communism, or make their 401k lose value among other detriments. As long as the motor was designed to run it, it's fine.
Ethanol isn't preferable, but not harmful since the MoCo builds fuel systems out of alcohol resistant materials, and at least on new closed loop fuel systems account for the lower energy content.
Since alcohol has less energy than gasoline, your fuel consumption goes up and you have to gas up more often. That's kind of a big deal to me since motorcycles have small gas tanks. So I always try to gas up at non-oxy premium fuel stations, and only those that are Top Tier.
In a pinch, I will sacrifice non-oxy to keep the Top Tier. For instance, Shell is Top Tier but doesn't offer non-oxy here.
Look up AAA independent test of gasoline to see how much cleaner intake valves and fuel injector nozzles are with Top Tier gas. It's very important.
Guess youve never had a small engine to worry about. Store your generator/mower/chainsaw without draining the carburetor (draining gets every drop as opposed to running engine until it stalls) of e-gas and youll be doing a carburetor cleaning or rebuild eventually 🥴
Guess you’ve never had a small engine to worry about. Store your generator/mower/chainsaw without draining the carburetor (draining gets every drop as opposed to running engine until it stalls) of e-gas and you’ll be doing a carburetor cleaning or rebuild eventually… 🥴
I thought we were talking about motorcycles. I'm guessing there are lawn mower and generator forums out there somewhere.
