Oil Pump Change without pushrod removal
Old Apr 18, 2023 | 09:12 AM
VTwin Rob's Avatar
VTwin Rob
6th Gear
Default Oil Pump Change without pushrod removal
Hi
2019 Softail 107.
Does anyone know if it's possible to change the oil pump without having to remove the pushrods, is it possible to get the vavles/lifters all in a closed position so there's no load on the cam?
I have a new oil pump and I'd rather not have to fit adjustable rods and the expense etc
Thanks in advance
Old Apr 18, 2023 | 09:25 AM
chopper_man's Avatar
chopper_man
There is always pressue on the cam, exhaust, intake, opposite cylinders. Just cut them and put in adjustables.
Old Apr 18, 2023 | 09:30 AM
MTBIG G's Avatar
MTBIG G
No way around it. Pushrods have to be removed due to tension on the cam and camplate. Takes more time, but you can remove and reuse the factory pushrods if the expense for adjustables is a concern.
Old Apr 18, 2023 | 10:46 AM
Keithhu's Avatar
Keithhu
Originally Posted by VTwin Rob
Hi
2019 Softail 107.
Thanks in advance
If I'm wrong, my apologies, but looks to me like you want to replace the pump to prevent sumping. I woulnd't bother, the overwhelming majority of sumpers were liquid cooled touring bikes.
Old Apr 18, 2023 | 11:17 AM
cobra23's Avatar
cobra23
I would contact Fuelmoto and ask them. They have tons of experience and good tech support
https://www.fuelmotousa.com/contact.html
Old Apr 18, 2023 | 11:27 AM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Seems like I saw a picture once posted by fuel moto where they changed an oil pump without removing the cam or push rods, but probably isn't recommended for the average do it yourselfer.
Old Apr 18, 2023 | 11:28 AM
VTwin Rob's Avatar
VTwin Rob
6th Gear
yea that's the reason, I've been given a almost new 2022 oil pump and was gonna fit that.
Old Apr 18, 2023 | 11:31 AM
VTwin Rob's Avatar
VTwin Rob
6th Gear
yep that's exactly my reason, maybe I'll leave it.
Old Apr 18, 2023 | 11:32 AM
mjwebb's Avatar
mjwebb
sell it on eBay and use the proceeds on gas and go ride!
Old Apr 18, 2023 | 12:29 PM
NZLowrider's Avatar
NZLowrider
if you were going to the bother of replacing the oil pump I'd go for an S&S, Feuling or even screaming eagle one myself
