Installing M8 Cam Plate
Old Apr 23, 2023 | 10:58 AM
propflux01's Avatar
propflux01
Default Installing M8 Cam Plate
I've been watching different videos and instructions on installing cams and ran a across a difference in how cam plates are installed. In many videos, the cam is installed, the oil pump is installed, then the cam plate, then the bolts, then torqued down per the manual. Others (like feuling), show taking the cam, and pump, installing it into the cam plate, holding the pump in with the four bolts lightly, then installing it as an assembly into the engine, installing the remaining bolts, then torquing from there. So is there a real difference in the end result in these two methods? Is one "better" than the other? Is there a reason why its done in these two different ways? or does it really matter? Just ran across the two different methods and got me curious about the 'whys' of each.
Old Apr 23, 2023 | 03:30 PM
Gripfxbbs's Avatar
Gripfxbbs
Literally doesn't matter. I noticed that when doing research too. I went with the. Install cam and oil pump first. Then cam plate method.
all roads lead to the sane destination.
Old Apr 23, 2023 | 03:54 PM
GmanHawaii's Avatar
GmanHawaii
Oil pump installed first to check clearance to make sure its seated properly into the O ring and flush.
Important step, checking pinion shaft runout, most require .005 or less.
Old Apr 23, 2023 | 06:42 PM
stormin08's Avatar
stormin08
chain alignment of the gears also...
you know ot install everything lightly and spin to align,
torque pump, cam plate, install gears to 15 lb/ft...check gear alignment, if with in .009", your good, otherwise shim to correct.
then torque gears in the proper steps
Old Apr 23, 2023 | 06:43 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
The Logic is simple.
1. CamPlate is touch/snugged first so that it will stay in position once positioned.
2. Engine is Rotated to center the cam plate on the pinion shaft.
3. CamPlate is Tightened down for final Torque.
4. (1 and 2) Oil Pump Bolts are touch snugged.
5. Engine is Rotated, Oil pump bolts are all final torqued.
This 1. Centers the Camplate separate of the Oilpump and influences so that the plate is centered, But the Oil pump is free to move around as it needs to so that 2. The Oil Pump can be centered as much as it can be.
You dont want the CamPate and Pump Torqued down together because then one or the other will have a tight spot that will wear. Tightening them down separately lets everything find it's center on it's own, reducing tight spots through out the system.
I know Feuling's system says to install the pump on to the plate then install it, but I just don't agree with this because it doesn't let the oil pump center itself independently of the CamPlate.
This is the sequence I used, derived from all of the pump install videos and instruction sheets from HD, S&S, and Fueling.
M8 Oil Pump Install Sequence (Drill Step can be replaced with torque wrench and torque settings)
Touch Snug the bolts in sequence.(Hand Tool)
Rotate the Crank Shaft.
Drill Snug the Cam Plate (3 to 8) (Drill Clutch Setting 1, approx. 3~5ft lbs.)
Rotate the Crank Shaft, several times.
100inch pound Torque The Cam Plate
Drill Snug the Oil Pump(except 9 and 10)
100inch pound Torque the Oil Pump.
Wait.(15min)
110inch pound final Torque full sequence 1 to 10.
Old Apr 23, 2023 | 07:18 PM
propflux01's Avatar
propflux01
I had always done it pump, cam, plate, then do the rote and center, the torque to specs. I just saw the fueling way and made me wonder why they had it set up they way they did VS the way I've seen it done most of the time.
Old Apr 25, 2023 | 08:29 AM
Fat11Lo's Avatar
Fat11Lo
I like installing the pump first so I can feel the housing slide in the O-Ring, seen way too many threads around here where the O-Ring gets damaged trying to install pump and plate together
propflux01
Engine Mechanical Topics
Apr 23, 2023 10:25 AM
WyoEglide52
11
Sep 5, 2021 02:54 PM
Sandcrab
Oct 1, 2020 11:32 AM
P51Driver
Milwaukee Eight (M8)
Aug 8, 2020 01:27 PM
roundy
Nov 5, 2015 10:26 AM
