Crank run out
Old May 27, 2024 | 08:34 AM
GPHDXLC's Avatar
GPHDXLC
My understanding is a crank run out of .006 or more can eat up the oil pump over time, as little as 35,000 ,miles. I'm sure that depends on how hard you ride it.
Old May 27, 2024 | 09:34 AM
Keithhu's Avatar
Keithhu
Originally Posted by GPHDXLC
My understanding is a crank run out of 00.6 or more can eat up the oil pump over time, as little as 35,000 ,miles. I'm sure that depends on how hard you ride it.
You have decimal point dislexia. It's .006
Old May 27, 2024 | 12:05 PM
GPHDXLC's Avatar
GPHDXLC
Just a slip up, look at post 3 I had it right. But thanks for highlighting my slip up😁
I fixed it...... But how about my question ??
Old May 27, 2024 | 01:16 PM
MTBIG G's Avatar
MTBIG G
Never hurts to check the runout if you're doing a cam change and checking is a must if you plan on running something like an S&S pump or gear drive cam. No offense of course, but here might be a little analysis paralysis going on here. That said, crank runout issues on M8s is a very rare. Lots of people running big hp M8s without problems on totally stock bottom ends. I've dug into a few M8s as well as twin cams, but I'm no expert. Might try calling FM to get there thoughts.
Old May 27, 2024 | 02:04 PM
Keithhu's Avatar
Keithhu
Jeez people are so uptight.
Old May 27, 2024 | 02:27 PM
goblue90's Avatar
goblue90
I just rebuilt my engine due to eating up my pistons and cylinders and seeing metal shavings in the oil pan (nothing huge, just sparkly bits in the oil). Anyhow, my stock crank runout was .008. I installed an S&S crank/flywheel assembly and am enjoying a runout of .001. The bike is also noticeably smoother.
Old May 27, 2024 | 02:38 PM
TwiZted Biker's Avatar
TwiZted Biker
Yeah, not looking forward to opening my 17 RK and checking the run out when I do the oil pump upgrade. But if it has to come apart I can true it and weld the damn thing myself. Just be a major pain in the ***.
Old May 27, 2024 | 10:35 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by Ohio HD
Well, TC or M8 the concept of gear drive is the same. Not considering any benefit from tensioner wear or replacement, gear drive will give a consistent accurate cam timing. For a bolt in cam, no, I don't see the need to spend the money. But with crank up builds using a strong straight crank, high compression, big valves and ported heads, and wanting the best performance that you can get from the motor, gear drive is a part of that.
Scott Palmer did some back to back tests for chain vs. gear and he stated gear drive made a little more power. That would have been in the early 2000's.
Back about the same time Blackhills Ken found the opposite was true.. IIRC he was running a HQ cam in a 124 ci Dyna.. He was running a chain and decided that he wanted the gear drive.. After the install, the motor made less power on his dyno.. If took a while but he found that the chain cam was running about couple degrees retarded from the gear cams.. Motor liked the cam retarded better..
Old May 27, 2024 | 10:47 PM
Ohio HD's Avatar
Ohio HD
Yeah, a few degrees one way or the other can bring it all together, or not sometimes. I think Scott was testing an 88 inch, I don't know what cam.
One thing that drives me crazy is when degreeing a cam, and measuring both cylinders (Twin Cam), I've learned there can be a few degrees between the two cylinders as well. I try to split the difference if one is too far off.
Old May 28, 2024 | 12:31 PM
Kadab's Avatar
Kadab
It feels smoother because the S&S crank weighs several pounds more than the stock crank.
