Once again you lack the ability to focus on the actual details of a post, you are slipping Max, some of us have noticed. The 3800 rpm guy didn’t describe a 3-4000 range, he said holding in the 3800 rpm for extended riding. If he said 3200- 3800 I would have left it. And possibly the poster meant that and just didnt make it clear. My original comment was cheeky as well, for the record
I cruise as close to 3000RPM as possible. I'm conservative when it comes to not doing burn outs, drag racing at stop lights, and so on. But when riding longs stretches of curvy roads and wanting to play around a bit, I'll ride consistently in the 3800 range for the sake of technique and the bike not feeling wobbly.
What does range mean? +- 250 RPM? +- 500 RPM? I chose +-750. If riding curvy road and wanting to play around a bit, I doubt he's keeping the RPM constant.
Add: You are right tho. I have been slipping.. Still on my 17 RK, that is about the RPM range I use on certain twisties.. Especially when a mountain is involved.
Reason: Add:
The pulses of the big engines at low rpm can be a bit annoying and they are sluggish below about 2800.
Well thats not even remotely true
Well, I cant comment on "annoying" as you clearly have a different threshold for annoyance than I do, but even bone stock my bike had a lot of nuts as low as 2000rpm.
After I installed the cam and other upgrades its almost ridiculous how much torque I have at low rpm. I twist the throttle and this thing launches. I kept sliding off the back of my seat.
I dont have to be turning 3500 rpm to get responsiveness...
Id like everyone to hop on your ride, get out to a country road and tool around for extended periods of time holding steady at 3800 rpm. Try just 5 minutes or even 2 and report back
Scott7d has over 225,000 miles on his 20 cvo, I would bet he knows how to ride. He probably has more miles on 1 bike than some of you wise guys have on all of your bikes combined.
I mean he's averaging over 40k miles a year living in the Midwest not west coast.
Yep, Scott7d has got some cred. We tracked him doing 100k in 100days a couple of years ago. I may not ride exactly the same way he does, but I sure as heck won’t ever suggest he’s doing it wrong.
I hope he keeps at least one bag filled with baby powder.
Yep, Scott7d has got some cred. We tracked him doing 100k in 100days a couple of years ago. I may not ride exactly the same way he does, but I sure as heck wont ever suggest hes doing it wrong.
That was Chris Hopper. I won't steal his glory But I still appreciate the kind words.
I probably could have been a little more clear with my "3800" post that started the whole pissing match. No, it isn't 3800 RPM straight for hours on end. Of course there is some variation going in and out of turns, some up shifting on the occasional straight-aways, etc. I figured common sense and intuition would kick in for people to realize what I meant in those scenarios. Maybe giving a range of 3500-4000 would have been less confusing. I'm so sorry.
Originally Posted by foxtrapper
How does an engine rpm keep your bike from feeling wobbly?
That's easy. Torque. Go ride some tight curves at 2000RPM then at 3500+. It will become clear very quickly. Engine braking at 2000RPM also isn't very effective. I rely quite a bit on that to ride in a spirited manner with rarely needing to touch my brakes. Even on routes like The Dragon.
