Lifter\Pushrod question
Old Jun 11, 2025 | 09:28 PM
Sparkules's Avatar
Sparkules
Originally Posted by Glenn Gorman
Hylomar blue gasket sealer? I don't see one for o-rings.
Just use the Hylomar Blue, yes it’s gaskets works dandy on a press to seat orings as our pushrods employ.
Old Jun 12, 2025 | 08:02 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
A trick to using Hylomar is to let it dry for at least 15 minutes before buttoning up.
Old Jun 12, 2025 | 12:52 PM
Glenn Gorman's Avatar
Glenn Gorman
Now ya tell me. Doesn't it say something about no fluids for 24 hrs too?
Old Jun 12, 2025 | 01:39 PM
Glenn Gorman
Didn't want to wait a week, so I picked up Permatex Ultra Black Gasket Maker. Not watery at all, nice and thick. Didn't read the instructions until I put the tube back together. Trying to let the bike sit for 24 hrs. before starting it up.
Old Jun 12, 2025 | 02:08 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I just realized you have adjustable pushrods...
Pull the pushrods and covers and replace the o rings.
Old Jun 14, 2025 | 09:27 PM
Glenn Gorman
I finally fixed my pushrod tube leak. Decided today to just put new S&S tubes, o-rings, springs and caps on. That fixed the oil leak. I trashed the Gold CNC pushrod tubes.
But now I have a check engine light. 99.9% sure that it's an exhaust leak from losening the dam exhaust so often. Just put two new seals in the freezer.
Old Jun 15, 2025 | 06:32 PM
Glenn Gorman
I never plugged in the rear clutch side spark plug wire. Thus the check engine light. I was going to replace the header seals today. Even bought the tool off Amazon. But it's getting ready to rain and temp is 82, humidity is 84%.
Old Jun 16, 2025 | 02:36 PM
Glenn Gorman
All finished, but the tool didn't work. Holes are too far apart making the tool too tight going over the studs. I'll be returning it to Amazon.
I did freeze the seals over night and they basicly slipped right in the exhaust ports.
Old Jun 16, 2025 | 09:00 PM
propflux01's Avatar
propflux01
I bought this one:
Amazon Amazon
Works great. Maybe return yours to amazon.
Old Jun 17, 2025 | 01:31 AM
Glenn Gorman
Originally Posted by propflux01
I bought this one:
https://www.amazon.com/dp/B0C2GXW47G...d_asin_title_1
Looks the same, just a different color. Already started my Amazon return. Freezing the seals over night was the trick. Both, just slipped right in.
