M8 idle delay
Old Apr 18, 2026 | 07:20 AM
DeeRoe's Avatar
DeeRoe
Did an S&S on mine.....no regrets.
Old Apr 18, 2026 | 07:25 AM
pgreer's Avatar
pgreer
Agree with the post above, S&S. FuelMoto has a nice one too, along with a CNC ported one but with a mostly stock bike that is unnecessary.
Either way, do the ignition on off cycle as describeds abvoe first.
Paul
Old Apr 18, 2026 | 08:40 AM
Hoginedgewood's Avatar
Hoginedgewood
the screaming eagle part says the computer needs recalibrated, did the S&S need it?
Old Apr 18, 2026 | 08:50 AM
pgreer's Avatar
pgreer
S&S has a standard alimunum manifold and a CMC ported performance one. There were no installation instructions for the standard one, but there is for the CNC ported one. I did not see a recommendation to perform a tune on the engine, but if it were mine I would,
See attached S&S document.
Paul
Old Apr 18, 2026 | 08:56 AM
DeeRoe's Avatar
DeeRoe
I did all of stuff through FuelMoto. I have a PV3. Told them what I had added (for me, pipes, intake and throttle body. They sent me a new tune. Flashed it. Smooth like buttah.
Old Apr 18, 2026 | 10:07 AM
Hoginedgewood
Originally Posted by Old Sport
Does this also happen when you’re stopped and blip the throttle?
May be a lean condition.
i tried blipping the throttle today, didn't notice idle holding high, but it was less than 15 miles and temperatures were in the 70's
Torkmizer's Avatar
Torkmizer
First off, what the OP described is pretty much normal when coming to a stop. Idle around 1100-1200 and then gradually returns to around 850-900. Now if it stayed high (usually much higher) then I would say warped manifold/vacuum leak. Harley makes an aluminum manifold identical to the stock plastic one for the M8s. It also is around $200
Old Apr 18, 2026 | 10:11 AM
Hoginedgewood
yeah, sitting here from memory, im thinking less than 10 seconds and it's bouncing around 900, I'll pay more attention before digging into it. It only mid April.
Old Apr 18, 2026 | 10:44 AM
joenc's Avatar
joenc
this is what my 2023 fatboy does....... since brand new....... complained, 3 times to dealer, they
checked it and said it's normal..... even test drove another brand new fatboy at the time and it
did the same as what torkmizer said above......... my dealer said only fix it to buy a tuner...
kind of pissed me off .... and pissed that harley got rid of the idle screw on my stock bike
Old Apr 18, 2026 | 02:05 PM
Old Sport's Avatar
Old Sport
That’s not my experience with my M8 (117ci).
A delayed settle to idle (from high rpms to low) indicates a lean idle mixture - whether this is the idle air/fuel mixture settings or a manifold leak, there is more air in the mixture than should be.
For the record my M8 has pipes, cam, high-flow filter and a PowerVision tuner - not a stock tune - but the same principle applies.
