Trike Rear End
Here's some info from manufacturer:
This is a brand new rear end with chain sprocket. Chain allows you to mount your axle anywhere you want and cut the chain to size.. You can't do that with a belt. Also takes out the guesswork and costly mistakes in purchasing the wrong length belt.
The pumpkin is vented, which not only allows for better cooling, but allows debris to fall out.. With others if a rock kicks up in the pumpkin off the chain it becomes trapped & can destroy your internals.
This axle kit uses dual 4 piston calipers that give you a total of 8 pistons stopping your bike vs. older designs which has 1 piston per side. These calipers are the same sold by Custom Chrome, DNA, & Ultima... Replacement pads are a breeze to find at any shop and your not stuck relying one one place to sell you pads.
Pumpkin is made of lightweight aluminum and axle from steel so you can weld on any fender mounts if you choose. Open Slip-Differential to help when making turns and disassembles with ease.
5 lug 4.75" Wheel pattern found on common Chevy wheels.
37.5" Width rotor to rotor.
42.5" Overall length
