Rushmore Right Side Heat Issue Project
Old Feb 7, 2016 | 02:25 PM
OldMike's Avatar
OldMike
Default Rushmore Right Side Heat Issue Project
I used heat shield pads from Amazon which I formed using my stock exhaust as a mandrel, hose clamps and a hammer helped. The top stainless pad is rated at 1800 degrees, the bottom aluminum pad is rated at 900 degrees.
This is a working prototype to see if it works and holds up. The pictures will explain the rest.
Amazon.com: Heatshield Products 110614 Inferno Shield 6" x 14" Aluminum Heat Shield: Automotive Amazon.com: Heatshield Products 110614 Inferno Shield 6" x 14" Aluminum Heat Shield: Automotive
Attached Thumbnails Rushmore Right Side Heat Issue Project-heatshield-001.jpg   Rushmore Right Side Heat Issue Project-heatshield-002.jpg   Rushmore Right Side Heat Issue Project-heatshield-003.jpg   Rushmore Right Side Heat Issue Project-heatshield-006.jpg   Rushmore Right Side Heat Issue Project-heatshield-007.jpg
Old Feb 8, 2016 | 06:22 PM
cdestuck's Avatar
cdestuck
Anxious to hear your findings on this. Maybe youre on to something big
Old Feb 8, 2016 | 07:46 PM
OldMike's Avatar
OldMike
Originally Posted by cdestuck
anxious to hear your findings on this. Maybe youre on to something big
huge!
Old Feb 8, 2016 | 08:23 PM
homerboy35's Avatar
homerboy35
Can't wait to hear your results!
Old Feb 8, 2016 | 08:37 PM
lp's Avatar
lp
Fingers crossed for you. Usually that kinda thing ends up holding moisture and the pipe rusts but since you're not wrapping the whole pipe it will probably be fine.
Old Feb 8, 2016 | 08:43 PM
OldMike's Avatar
OldMike
Yes, it is not a wrap or cloth but a metal honeycomb finish.
Even with a no cat head pipe my right leg roasts in the hot weather, this should fix that. The first hurdle was to see if it would fit behind the stock heat shields so it is not noticeable be the casual looker.
Old Feb 8, 2016 | 08:52 PM
steelerdude1's Avatar
steelerdude1
I like your thinking. I was also trying to put some thought into this wondering if I could fab up some sort of heat deflector.
If your idea works, it will sure be prettier than my thoughts, LOL
Old Feb 8, 2016 | 08:56 PM
OldMike's Avatar
OldMike
I went through a lot of ideas too, most would look like crap, this addresses almost all of the heat emitting area close to the right leg.
Old Feb 9, 2016 | 07:04 AM
GTK's Avatar
GTK
Thanks for sharing your mods.If it works out,there is hope for us all in the hot leg problem.
Old Feb 9, 2016 | 09:45 AM
OldPhat's Avatar
OldPhat
Subscribe
