Moving to PA, what do I need to know about inspection?
I haven't had a vehicle inspected in 20 years living in Florida, so what do I need to know about inspection in PA? I'm moving to a county that doesn't require emissions, will my V&H exhaust be an issue? My bike is all stock on the outside except for CD LED signal bulbs and smoke lenses. Otherwise it is a stage 2 with SE ventilator intake, cam, and exhaust. Anything I need to do for inspection or will it be fine?
Also, my Trans Am is bone stock engine wise with the exception of the secondary air injection being removed. Will that be an issue? I'm planning on registering her as a classic if possible, but not sure.
No Issues. You will have to go to an inspection station that is familiar with bikes. I just go to a local speed shop or the dealer depending.
If they do all that is required they will check to make sure the lights and signals are working, brake pads, and tire wear. Safety stuff.
Car will be no issue either. Same stuff checked
Just curious, what county ya moving to?
My sister wanted me to join her in VA, but I told her I won't live in a state that requires a front license plate
. She thinks I'm nuts!Trending Topics
I think classic is you get it inspected once and if it passes thats it. Emissions, post 1996 cars , (OBD 2) you cannot have a check engine light on. Cars, they can fail anything safety related, ball joints, tie rods,struts, shocks, cracked windshield, tires less than 2/32 on two adjacent treads etc. Thing in Pa is its not standard, one guy will fail your stone chipped windshield, and the guy down the street will pass it and sticker it. basically if it isn't a total POS you should be ok. Find a good private small shop where you can talk directly to the owner or mechanic, don't deal with chains shops they have inept counter people who will BS you and youll want to talk to the guy working on your car and they will try and prevent that. This is just my $.02
Enough about cars, Pa is good riding alot of two lane twisty hilly scenic routes, if you live here you are used to it,Pa sucks in other ways but for the scenery and riding,that isnt one of them, the cagers ruin it though but thats was always the case.
Look up McChesney motors (Bob) when you get settled. He's up near Clearview mall, off of 422. Best independent shop around. He's an older guy thats been around a long time. I recently moved up to Sarver, PA (Butler county) and everyone I've talked to says go to him. I only bought tires from him so far and I can't complain.
