Oil Archive (no new posts) An archive of oil related questions and comments.
oil filter stuck on sportster
Old Mar 19, 2016 | 11:22 AM
mirrorman's Avatar
mirrorman
Default oil filter stuck on sportster
I will start changing my own oil as of right now that way I can do it whenever I please. I only have one problem, the oil filter that the dealer used is stuck. I tried brute strength and the reversed masking tape sticky glove method but it's hard to get even my tiny hands around that thing. I have a couple of chrome k&n filters that I will use because they come equiped with a built in nut attached to the filter itself. I did see what looked like a filter wrench type tool at walmart in the k&n section. It looks like an inverted filter head that fits over the filter to wrench it loose. I will try that but if that doesn't work then I have no idea. My royal purple oil arrived today so I want to get the oil changed this weekend. Anyone else had a filter problem with their sportster?
Old Mar 19, 2016 | 11:28 AM
Uncle Chester's Avatar
Uncle Chester
I've had to punch a screwdriver through the oil filter to use as a lever before. That'll usually get um off pretty easily. Just make sure to have a funnel of some sort under the filter when you do this as it will dump oil all over the place.
Old Mar 19, 2016 | 12:01 PM
nevil's Avatar
nevil
The wrench you found at Walmart should work, it's the same type I use. Like mentioned you can always punch a hole in it, never fails but can be messy.
Old Mar 19, 2016 | 12:08 PM
SWMB's Avatar
SWMB
You'll get it off just have to persevere. I'm just going to add a little advise on putting the new filter on oil the gasket and only hand tighten do not use a wrench on your K&N filter to tighten.
cmosentine
Apr 21, 2016 05:13 AM
kpb46
Feb 19, 2014 08:19 PM
kpb46
Jan 7, 2014 11:04 PM
mjaw
Jun 23, 2009 07:16 PM
jpnelson1978
Jul 24, 2006 06:28 PM
