Thanks Harkon,
Roadmutt pointed me in the right direction. Harley Davidson packs the new breather asemblies in the incorrect postions/order, which woud require the Master Automobile Technician / Novice Motorcycle Mechanic to disassemble it out of the package and reassemble it correctly prior to installation. HaHa Harley Davidson, you got me on that one,
Thanks Again,
JJ
Thanks Prodrag,
I didn't remove the lower rocker box, just the upper and rocker arms to remove the pushrods. I installed new "updated" breathers while apart during the cam chain tensioner replacement process, which resulted in the problem of "no breather function."
Roadmutt pointed me in the right direction. Harley Davidson packs the new breather asemblies in the incorrect postions/order, which woud require me, the Master Automobile Technician / Novice Motorcycle Mechanic, to disassemble it out of the package and reassemble it correctly prior to installation. HaHa Harley Davidson, you got me on that one,
Thanks Again,
JJ
