Oil Archive (no new posts) An archive of oil related questions and comments.
Pipe Plugs What For?
Old Nov 21, 2005 | 10:04 PM
dowe66's Avatar
dowe66
3rd Gear
Default Pipe Plugs What For?
Does anyone know what these pipe plugs do? Can they be used for a 5 quart oil change. Looked in the manual and say nothing about these guys.
[IMG]local://upfiles/5781/DA596C09BDBA445E91B48A34B10A9BD2.jpg[/IMG]
Old Nov 21, 2005 | 10:28 PM
RonnieJ's Avatar
RonnieJ
Default RE: Pipe Plugs What For?
They keep the oil in
Old Nov 22, 2005 | 04:55 PM
dowe66's Avatar
dowe66
3rd Gear
Ronnie J, I know that! but there has to be another reason why the factory would put those in. It brings the cost of the part up having to do the extra machining and allen studs. I know that if they can save a penny per bike at the factory, they are going to do it! So there must be some other reason than what you have explained. But thanks your intentions were good!
Old Nov 22, 2005 | 10:28 PM
markster6828's Avatar
markster6828
They are casting plugs, not intended to be used. In the actual casting/making of the part process, it leaves these holes. The plugs are just to cover the holes and to keep your oil from running out.
They do look like a good place to hook up an oil cooler, but then all your oil wouldn't be filtered.
Old Nov 23, 2005 | 12:47 AM
dowe66's Avatar
dowe66
3rd Gear
Thanks markster6828 thats what I wanted to know. It is too bad that you cant run a cooler on it. I was thinking that you may be able to do a five quart oil change using these ports, if you had some type of valve on the return line to the oil sump. Thanks again.
elchoche23
May 26, 2019 12:12 PM
ronnierhino06
Oct 19, 2014 07:31 PM
CDNbob
Jul 13, 2011 07:04 PM
McGillea
Jul 13, 2011 05:43 PM
shortleg
Feb 15, 2009 07:12 AM
