Oil Archive (no new posts) An archive of oil related questions and comments.
Oil Breakdown At Temps
Old Dec 12, 2005 | 05:36 PM
HDF Tech's Avatar
HDF Tech
Default Oil Breakdown At Temps
When extreme overheating situations exist, oxidation is rampant. The only cure for oxidation is changing the oil. Extreme heat indicates the need to change your oil more frequently.
Your fossil oil's effectiveness in lubricating drops off once its temperature increases beyond 250" F.
Oil Oxidation Rate Chart
When observing the accompanying oxidation rate chart, it will become readily apparent that heat is the enemy and must be controlled. With heat comes oxidation of the oil and the only cure for this is to change the oil. When extreme overheating situations caused by improper tuning or a brutally hot summer day exist, oxidation is rampant, so change your oil more frequently.
Source: Heavydutycycles
arnie54
22
Jan 20, 2014 11:32 AM
viarengo
Feb 26, 2013 09:25 PM
car5car
11
Dec 4, 2009 03:41 PM
dynarule
11
Oct 2, 2009 05:13 PM
nobody
EVO
Aug 5, 2008 01:58 AM
