Oil Archive (no new posts) An archive of oil related questions and comments.
Synthetic Causes Bearing Cavitation
Old Jan 15, 2008 | 08:46 PM
HogGlider's Avatar
HogGlider
Default RE: Synthetic Causes Bearing Cavitation
ORIGINAL: bullelkklr
Was talking to a local Indy (denver) and he told me that synthetic oil is causing the main inner bearing to cavitate and the bearing goes out.
So I am thinking Fooey.
He goes on to say that the oil is so slippery that the bearing simply stops rotating and a flat spot is created. But this only happens at certain speeds/rpm's when the cruise control is locked and at highway speeds. He took me to the back room and showed me a bearing/crank on a bike this happened to. Showed me 9 other bikes that were in because of this happening to them.
So, my question is - has ANYONE else heard of such a thing anywhere in these here United States that might possibly confirm such a bold statement?
I'd like to know who the indy was (I am from Arvada), I am still trying to find a decent one around here as the only good one I have heard about was up in Ft. Collins and I hate the idea of riding that far to Dyno.
Old Jan 16, 2008 | 10:09 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
This "bearing skate" idea is the oldest wives tale of the last century. Synthetic oils are just better and HD syn3 is a good group III oil as well. That said there are better GroupIV and GroupV syn oils out there for the same price. There are some gear oils that are "too slippery" for transmission applications that involve sychronizers but those are automotive related not motorcycle related. None cause "bearing skate".
Old Jan 16, 2008 | 12:25 PM
huffhuff's Avatar
huffhuff
66K miles on my 2001 RK using Mobil 1 15W50 car oil since first change. nengine has been apart three times for modifications and no visible wear was found anywhere. my chain tensioners lasted 54K.
Old Jan 16, 2008 | 03:04 PM
fxrp's Avatar
fxrp
ORIGINAL: huffhuff
Mobil 1 is an interesting subject. Sure they changed some additives (mostly just ppm) so it could be argued that its a different blend. But in reality they just slapped a 20-50 MC label on the 15-50 motor oil and added $2 to $4 to the price.
Old Jan 16, 2008 | 08:28 PM
iclick's Avatar
iclick
Ask your indy when my old RK's bearings will fail. It has 110k on it now, the heads have never been removed, and has had a diet of synthetic oil since 9k.
Old Jan 17, 2008 | 07:26 AM
Uncle Scrooge's Avatar
Uncle Scrooge
If your indy used a synthetic with flouride added, it would help reduce the cavitations.
Old Jan 17, 2008 | 07:32 AM
lionsm13's Avatar
lionsm13
Yup; what everyone else said; old wives tale. BS.
Old Jan 17, 2008 | 11:58 AM
WildBill2566's Avatar
WildBill2566
I don't think you should just dismiss this bearing skate. I'm sure its been scientifically proven.You just cannot be too carefull. This pushed me into action, cause I got to look after my ride.
I dropped out that darn synthetic oil and put in some used dyno oil. I figure since its used, its already been tested by someone else. You wont catch me doing the oil companies research for them, no sir. I'm too smart for that. Used oil, its the way forward.
WB
Old Jan 17, 2008 | 12:51 PM
sleepneagle's Avatar
sleepneagle
ORIGINAL: WildBill2566
WB
I'm with Bill, I re-re-refine used oil in a distillery in my backwoods. Filter it with toilet paper rolls to clean out the impurities. I don't know if it ends up being 10-40, 20-90 or what. works good, I figure it ends up being a syn blend cause I don't know what was in the dippin bucket. Once I finish with the toilet paper rolls, I carry them up to the house and recycle them. After all it is prelubricated and will not chaff your backside. Not near as scratchy, you know. I believe in recycle.
Old Jan 17, 2008 | 08:42 PM
pococj's Avatar
pococj
ORIGINAL: sleepneagle
WB
LOL, y'all do know that the very best filter systems, bypass filters, used to use toilet paper rolls. Now they use a toilet paper roll, but it's made strictly for them.
