Oil Archive (no new posts) An archive of oil related questions and comments.
oil leak
Old Feb 25, 2006 | 12:07 AM
1sportytrike's Avatar
1sportytrike
Default oil leak
I took my trike to a dealer to get it checked over and while I was there I went ahead and had them change all the fluids. Now I notice a little oil on my exhaust and on the fender. I can't find where the oil is coming from and it's not a great amount of oil but I was wondering if something could have been left a little loose and under driving conditions lets a little oil blow out. It didn't do this before the change and there are no oil spots on the garage floor and like I said I can't see any place where oil is seeping out but every time I get done riding there is oil on those two places. Any ideas?
Old Feb 25, 2006 | 12:27 AM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
Default RE: oil leak
Coming outta your air cleaner..... There is tons of advice here on that issue. Mine does the same thing, I put a maxi pad on the bottom of the inside of the air filter cover
Old Feb 25, 2006 | 12:40 AM
1sportytrike
Actually I was kind of wondering if thats where it came from. What causes it, bad gasket? And will it get worse if I don't get around to fixing it soon?
Old Feb 26, 2006 | 04:54 AM
WildBill76's Avatar
WildBill76
Check you oil level hot. I bet they put a half quart too much oil in.
Old Mar 1, 2006 | 07:24 PM
vernh59's Avatar
vernh59
Its common to have some oil blow out the breathers. With the original air filter the oil should be pulled back into the engine through the carb. With the Hi Flow air filters the oil gathers inside the air filter cover and drips onto the timing cover and sprays the right side cover and bag. (on my RK). [:@] I think this is made worse by overfilling the engine.
KeeBee
Oct 8, 2014 07:03 PM
WideGlideFever
Dec 16, 2013 09:10 AM
rperk60
Jul 29, 2013 04:57 PM
gonpce
May 17, 2013 07:45 AM
Gary hurst
Jul 14, 2012 04:54 PM
