Oil Archive (no new posts) An archive of oil related questions and comments.
Using Engine Guard as Oil Cooler
Old Jun 30, 2008 | 07:10 AM
venture's Avatar
venture
2nd Gear
Default Using Engine Guard as Oil Cooler
Someone told me, I could use the engine guard as a oil cooler.
It looks quite a good solution. someone having experience with this, or did try it?
drill holes in both lower ends of the guard, tap a plug in it and connect the oil tubes to these plugs.
need more oil in the engine, while the oil circuit has expanded.
Old Jun 30, 2008 | 07:30 AM
silvrbill's Avatar
silvrbill
Default RE: Using Engine Guard as Oil Cooler
Lots of info on this set up if you look for it here. Sounds good but if you go down and puncture or&nbsp\\;break the guard or a fitting I wonder what the chances are of getting sprayed with hot oil?
Old Jun 30, 2008 | 08:51 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
You can do it but be sure to flush out the inside very well first. I would not simply because of the thermal characteristics of the pipe itself versus a finned radiator. Radiator cools better. But any oil cooler that adds more oil to the sump is good as the more oil you add the cooler it runs and the longer the oil lasts.
Old Jul 2, 2008 | 09:29 PM
Asylumcycle's Avatar
Asylumcycle
&nbsp\\;I would agree with KBFXDLI&nbsp\\;as I work on bikes @ night and weekends and cars during the day. The fins are there for a reason, nothing cools better than fins, just like your engine, notice your engine is not just a solid block, but finned for a reason.
Old Jul 7, 2008 | 12:02 PM
ElectraGlideClyde's Avatar
ElectraGlideClyde
Doesn't sound like a very good idea.&nbsp\\; It sure would make your engine guards hot.&nbsp\\; Why not just put an oil cooler on it?
pilot1996
18
May 9, 2017 11:54 AM
TwiZted Biker
Milwaukee Eight (M8)
Feb 2, 2017 07:26 PM
fishcop
Oct 24, 2009 09:43 AM
dert
Jul 25, 2006 09:47 AM
firestar99
Jun 12, 2006 05:10 PM
