Oil Archive (no new posts) An archive of oil related questions and comments.
oil mark cold
Old Aug 26, 2008 | 12:52 AM
Jessie's Avatar
Jessie
Default oil mark cold
I just changed my oil and I filled it to the 3/4 full hot mark but cold oil so 1& 1/2 mark's to much will that hurt being a line and a 1/2 over it is still 2 squares down from the full hot mark ?
Old Aug 26, 2008 | 06:00 PM
wildpig1ms's Avatar
wildpig1ms
That's usually where I fill my big twin evo up to and when it gets hot, it's on the full mark...next time you take a twenty minute ride just check it and see where it is...make a mental note for the next time if it's a little too full when hot....a plastic syringe and hose will pull a little out if needed....but you're probably fine....
Old Aug 27, 2008 | 12:24 PM
EZ2Rider's Avatar
EZ2Rider
Jessie, overfilling a LITTLE BIT, won't hurt anything but may cause you to vent some oil through your air filter. that won't hurt anything either except, maybe, stain your pants and get the cam cover oily. IF it really bothers you you can remove a bit with a turkey baster or mini pump.
Normally, I run mine a bit low, filled to the half mark and when it is hot, it is between 3/4 and full. Anything between the add and full marks is fine, cold.
We agonize too much and ride too little when oil becomes a big focus, IMHO.
EZ
latrappe
EVO
Dec 11, 2017 10:25 PM
Falcon195
Jul 21, 2013 11:28 PM
uscanuck
May 26, 2011 01:00 PM
agent58
May 24, 2010 08:10 AM
BucksBike
Jun 7, 2009 03:09 PM
