Oil Archive (no new posts) An archive of oil related questions and comments.
Drain Plug...
Old Oct 28, 2008 | 08:40 AM
onemotochica's Avatar
onemotochica
Default Drain Plug...
I am simply doing a 27,500 engine oil change and will do comoplete service at 30. Is there a tourque recommendation for the engine oil drain plug?
Also any other advice for sealant, loctite, or anti sieze...???
I will be buying the service manual...2000 road king flhri
Old Oct 28, 2008 | 03:53 PM
EZ2Rider's Avatar
EZ2Rider
About 20 (twenty) INCH lbs. Make sure the O ring is intact or replace it and don't overtighten and defeat the O ring. Think "snug" not fused. LOL.
No sealant needed.
Old Oct 28, 2008 | 04:51 PM
kopec_wayne's Avatar
kopec_wayne
2nd Gear
I have always just tight snug - about 20 ft/lbs ( service manual - 14 - 21 ft/lbs )
NO tears in Oring= ok to reuse, I use a high temp thread sealant, can't stand leaks, moght as well overdo NEVER underdue Anything, Rule of thumb, if you know you can do a job in 15 mins, might as well slow her up and just take your time ! better safe than sorry.
Old Oct 28, 2008 | 09:36 PM
2deuce's Avatar
2deuce
I've always used teflon paste on all the drain plugs, no problems - no leaks.
Old Oct 28, 2008 | 10:10 PM
Nightrider2's Avatar
Nightrider2
Make SURE you have the right plug, a guy i know didn't , split the bottom of his case, now, he's got to replace BOTH cases.
Old Oct 29, 2008 | 08:21 AM
EZ2Rider's Avatar
EZ2Rider
Sorry, FOOT Lbs is CORRECT! Senior brainfart!
Old Oct 31, 2008 | 01:05 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I use white loctite on my drain plugs. It is hydraulic locker/sealer and works fine.
Old Oct 31, 2008 | 01:08 PM
anubisss's Avatar
anubisss
Someone has gotta say it. All that info is in the manual. Best $60 you will ever spend. I'm not a torques guy either. Just snug it up tight here...And I only replace the or ing if it is trashed.
Old Oct 31, 2008 | 02:17 PM
onemotochica
Just bought it. It's great!!
Torpedo1
Jan 29, 2019 10:30 PM
rick775472
18
Jun 6, 2015 05:51 PM
Timekeeper10
Jul 2, 2013 12:34 PM
ultraherbie
Apr 18, 2013 11:50 AM
eddiepoindexter
Sep 7, 2012 10:24 AM
