oil spraying
I made sure of the amount of oil in tank b-4 addin ne too it. So about starting over??? Are you sayin that maybe the idea about the Syn3 oil I changed too might also be the problem? Or that just goin back to ne non-Syn type motorcycle oil would be a better solution, regradless if it's HD360 or Mobil?
:edit: My first post stated that after the ride thrusday nite, when the oil started blowin again that by the time I got back home it had blown almost all the oil out of my tank. It was about 1 inch of oil in bottom of the tank b-4 adding 1 1/2 qts yesterday, which brought the level to the bottom point of my dipstick.
Type of oil issue - I changed an '87 Evo to Mobil 1 15w-50 at about 40k miles. There were no problems. While I think the Syn 3 is overpriced (HD tax, of course), it isn't a bad oil, and has nothing in it that would cause a motor to suddenly start blowing oil out compared to another type of oil of the same viscosity.
well KBFXDLI, I guess it did the job for them...
I tryed another ave to apporch this problem.Cleaned the K & N air filter with there filter cleaning solution and didn't oil it. Check oil level in tank, from the nite b-4 ride. Level in tank was 1 inch in the bottom of tank...added 1 1/2 qts
to bring level to just touching drip stick. Let bike warm-up about 10 to 15 mins and guess what happen??? Yes it started to leak out the breather again... [sm=WTFsgign.gif]
Now tonite I called a friend who is a Ace Mechanic (should of called him sooner
). First thinghe told me was not pleasant to my ears...get rid of the Syn3 oil!!! and clean the system out with 2 oil changes of H-D 360 20W50, flush system with first change while hot and do the second change and it should stop the blow back because with the evo havin over 25,000 miles and it start to act like that with Syn3 that the motor wasn't use to the new form of oil. Kind of make scents to me some what. [sm=yikesomg.gif]
, Checked the oil lines and they all operated great. Did change oil back to 20/w50, but still have syn3 mixed with 360.
The filter is the same as the replaced filter from Harley. part number 63796-77A
goin to run oil for about 50 to 100 miles than flush with another oil change & filter.
btw, goin to leave syn3 in prime & tranny a lil longer to see how it does. also is there
another way to help drain oil directy from the motor other than the line from oil tank.
To make sure I remove all the oil next time. The owners manual does show both a drain
line and a plug. [sm=thanx.gif]
