Oil Archive (no new posts) An archive of oil related questions and comments.
crankcase breather
Old May 16, 2009 | 11:02 PM
haasman1966's Avatar
haasman1966
Stage I
Default crankcase breather
i have a late 92 evo which is vented through the heads like a 93. it still has an aftermarket crankcase breather hooked up to the origanal spot at bottom of crankcase. it pukes a lot of oil. can i do away with it since my moter is vented like a 93?
Old May 17, 2009 | 08:39 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Is it a breather hose? If so try raising the length higher up and see if it still pukes oil. You can try eliminating it but could create a different issue.
Old May 17, 2009 | 03:46 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Did it come from the factory configured as a head breather, or was it changed to head breather, just wondering if all the components are in the engine to allow it to be a true head breather. Heads, rocker covers,umbrella valves, cam cover.
I don`t think a head breather uses the crankcase vent.
dibe
EVO
Apr 1, 2017 06:14 PM
Ben Jefferies
Engine Mechanical Topics
Oct 3, 2016 10:48 AM
pikeslayer
Exhaust System Topics
Mar 24, 2011 08:28 AM
denn
Oct 3, 2010 05:24 PM
greenyetti
Sep 8, 2010 05:04 PM
