Oil Archive (no new posts) An archive of oil related questions and comments.
OIL LEAK! HELP!
Old Apr 28, 2005 | 05:00 PM
smudge's Avatar
smudge
Default OIL LEAK! HELP!
Rode the 20 miles into work this am and noticed oil all over the right side! It's like a fine mist, coming from underneath the carb and spraying back onto the oiltank, rear shock and saddlebag. Looking at previous posts, I'm not sure if this is "normal" or not. It's a '99 Evo motor with low miles. Someone suggested head gasket, but I don't think so (I hope). Should I panic? I've only had her 2 days!!!
Old Apr 28, 2005 | 07:00 PM
TxMoores's Avatar
TxMoores
Default RE: OIL LEAK! HELP!
Don't worry!! Take a rag along with you and when you stop, wipe off the air filter and bottom of the gas tank. You might try lowering your engine oil, but still keeping it in the acceptable range. There are several solutions including ‘The Cure’ from CCP http://www.directparts.com/ccp/cure.htm , Kuryakyn rocker arm covers, adding a crankcase breather system, Krank vents, etc….
Old Apr 29, 2005 | 01:05 AM
pococj's Avatar
pococj
Find out if it is coming from the breather system, or if you've lost a pushrod tube gasket, or a head gasket is getting ready to let loose.
Old Apr 29, 2005 | 01:25 AM
John TN's Avatar
John TN
A couple of good suggestions already, is this the first time you have had a problem, and have you done any mods to the bike recently.
Old Apr 29, 2005 | 12:08 PM
smudge's Avatar
smudge
Thanks for the suggestions. I've made no modifications, I've only had her a week! However, it IS a custom, and the PO might have played around a little. I think I remember seeing among the receipts for the bulid, a bill for Crane cams! For now, I think I'll just A: Keep an eye on the level B: Carry a rag and C: RIDE!!!
Old Apr 30, 2005 | 08:32 AM
mikeisglidn's Avatar
mikeisglidn
i get one quarter sized drip at the end of the day, drivin me nuts!
cruiser66
Exhaust System Topics
Jan 7, 2016 02:49 PM
Cycopath
May 20, 2010 10:02 AM
jurob
EVO
Sep 21, 2009 08:24 AM
Rosco230
Jul 12, 2008 02:56 PM
humpyy57
Sep 1, 2007 07:51 AM
