Oil Archive (no new posts) An archive of oil related questions and comments.
DIY Scavenger Puck under $10.00
Old Feb 24, 2011 | 09:42 PM
  #31
krazy3's Avatar
krazy3
Originally Posted by sportsterleroy
If you are looking for a ready made item that does the same thing check out my buddy's site.
It is available to purchase online for $20.
He designed it in 2006 , and produced it for the market.
www.2armcyclestore.com
Hear is a link to the right up on it..
http://www.2armcyclestore.com/Binder1.pdf
Sportsterleroy
Sorry man, but my Avast just aborted me from reaching your buddies site
Old Feb 25, 2011 | 10:53 AM
  #32
sportsterleroy's Avatar
sportsterleroy
From: South euclid ohio-east side of Cleveland Ohio
My avg virus program did also alert me before I posted it , but opened a new window and all fine. I just opened using the link in the thread no problem.
Sportsterleroy
Old Feb 26, 2011 | 07:57 AM
  #33
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Sportsterleroy
Your buddy needs to fix his website. Google says it is known to be distributing malware.
Old May 24, 2011 | 10:18 AM
  #34
jcallesano's Avatar
jcallesano
anyone use this "other " product?
Old Jun 20, 2011 | 10:57 PM
  #35
Stretchman's Avatar
Stretchman
Read the associated article. It said something about the oil pressure to the engine using that setup. Kind of nixed it for me.
Old Feb 8, 2012 | 01:55 PM
  #36
JimA's Avatar
JimA
Since the oil filter on my evo is on the return circuit, couldn't I just put the fitting below in the home made scavenger? Would old oil still circulate through?
Old Feb 9, 2012 | 04:25 PM
  #37
JimA's Avatar
JimA
Something like this...
http://www.youtube.com/watch?v=TgHVyktZHuM
Old Feb 28, 2012 | 02:46 AM
  #38
Iron Butt Springer's Avatar
Iron Butt Springer
I'm confused as to why you need to use a puck? On a TC motor if you pull the return line and run the engine until you see clean oil what the problem? That return oil is upstream of the filter isn't it? Now if you have a cooler that would be a different story
Old Feb 28, 2012 | 03:02 AM
  #39
DOMAPOI's Avatar
DOMAPOI
All I know is that after I do an oil change on my Sportster, then start it up and run to normal temps. I then shut it off and recheck the oil lever. It is so clean that I have to touch the dip stick to a clean dry paper towel to actually see where the oil lever is on the stick. It is that clear still. Don't think there is that much left after draining the old oil and changing the filter. Even a week later it is still so clear I can't see it on the dip stick.
Old Mar 23, 2012 | 11:28 AM
  #40
geekonabike's Avatar
geekonabike
1st Gear
Default Also confused, but for my Sporty. Puck not needed?
Looking at the oiling diagram in my 2006 XL883's Service Manual, it seems like the oil goes
tank->feed pump->filter->engine->sump->scavenger->tank.
So if I drain the tank, change the filter, and fill the tank with fresh oil, the crud should come out of the scavenger while the good stuff goes through the filter to the engine to keep it from being starved. Also the new filter will filter the little bit of crud that was in the lines between the tank and the filter, if I'm reading this right. In other words, I don't see why a puck would be used in place of the new filter, unless there's enough oil in the tank->pump->filter to worry about getting on the filter, but not enough to worry about sending through the engine unfiltered?
The article http://www.aimag.com/wordpress/2010/...oil-change-ii/ doesn't seem to clarify logic of the puck either.
This looks like a cool forum.
Mike D.
