Oil Archive (no new posts) An archive of oil related questions and comments.
Oil question for Skip
Old Jun 12, 2005 | 06:51 PM
cyrilaudet's Avatar
cyrilaudet
6th Gear
Default Oil question for Skip
Hi
Thanks Skip for the good info about oil.
I am the owner of a 2003 883 Sportster.
My question is : What type of oil do you recommand for the primary chaincase of a Sportster ?
Thanks a lot .
Cyril Audet.
Québec
Canada
Old Jun 13, 2005 | 09:31 PM
pococj's Avatar
pococj
Default RE: Oil question for Skip
I'm not familiar with the newer Sporty tranny/primary setups. I know the old ones shared the transmission and primary oil, plus there was some interchange between the engine and primary. What does the owner's manual call for? Knowing that, someone on here might be able to come up with something.
Sorry I can't be of more help. Guess we'll both get to learn something on this one!
Old Jun 13, 2005 | 10:33 PM
cyrilaudet's Avatar
cyrilaudet
6th Gear
Hi Skip
Thanks to having take the time to respond.
Of course the HD manuel says to use Sport trans fluid - HD genuine.
But the bottle says nothing to what is inside .
When i change it tough it smells like Automatic trans. oil
Amsoil recommand their 20w50 synthetic.
Another guy recommand 75w90 gear oil. So i am a bit confuse ??
Thanks again for your response.
Cyril
Old Jun 14, 2005 | 08:45 AM
oldgeezer's Avatar
oldgeezer
You should be OK running the Amsoil 20W-50 but don't run gear oil. If you aren't sure, ask the shop guy at your HD shop if he would run HD Syn3 in the primary. If he says yes, then run Amsoil or Mobil 1.
Old Jun 23, 2005 | 12:29 AM
Mal74's Avatar
Mal74
I changed to Amsoil 20W-50 on my last oil change. I'm running it in my engine and primary. I have over 500 miles since I changed to total Amsoil, with no problems. I have noticed the oil temps are about 10 degrees cooler. I ain't goin back to Dino oil!
jerryw618
Jun 12, 2015 08:34 AM
steelerdude1
Jul 15, 2011 12:59 PM
TRAVIS174
Apr 8, 2010 06:17 PM
raksasas
Nov 20, 2009 07:49 PM
lou1
Apr 14, 2008 11:40 AM
