Oil Archive (no new posts) An archive of oil related questions and comments.
Wet Sump Solution?
Old Jun 14, 2005 | 02:33 AM
DevilDog3's Avatar
DevilDog3
6th Gear
Default Wet Sump Solution?
If I suspect excess oil due to a wet sump, is the solution to simply run the bike for a few minutes and then check the oil level, draining any excess? I believe a wet sump may still be causing unwanted oil pressure. Thanks.
Old Jun 14, 2005 | 08:36 AM
pococj's Avatar
pococj
Default RE: Wet Sump Solution?
Yep, that'll work.
Old Jun 14, 2005 | 08:42 AM
HDF Tech's Avatar
HDF Tech
Yes as Skip said,that'll work , but I don't think the wet sump can cause excessive oil pressure, just a loss of power if it is excessive oil. If it is a re occuring problem , you might consider realigning the oil pump as a possible cure.
baldy59
Shovelhead
Jun 24, 2017 12:18 PM
sportsteragain
Ironhead
Aug 30, 2011 10:36 AM
fireaxxe
Nov 20, 2010 01:15 PM
cabrillopr
Nov 4, 2009 06:13 PM
My Street Glide
Aug 26, 2006 04:27 PM
