Oil Archive (no new posts) An archive of oil related questions and comments.
Oil Pump "CHECK BALL" is Weeping Oil
Old Aug 24, 2011 | 07:46 PM
SCHOONER's Avatar
SCHOONER
Question Oil Pump "CHECK BALL" is Weeping Oil
Hey Guys (Newbe Here)
If only I can fix this oil leaking out of my oil breather I would
be a very Happy Clam
There's a CHECK BALL inside the oil pump. And its not seated correctly due to the fact oil is leaking out of my oil breather.
Question(s) Please:
1. I was told to lapp the inside of the oil pump after I take out
the check ball in the pump ! IS THIS CORRECT THING TO DO?
2. What do I do with the CHECK BALL once out of the pump ?
2a. Do I go over it with lap compound or what ?
Any thing you guys can tell me to STOP this leaking will be GREATLY APPRECIATED
Thanks guys
P.S. Check out photos of the MESSY OIL
After ALL the old oil came flushing out of the oil breather; there's still oil slightly/weeping thru the oil breather. Now I know that the oil pump CHECK BALL is the cause.
But what do you guys suggest I do from here ? ? ?
Attached Thumbnails Oil Pump "CHECK BALL" is Weeping Oil-check-ball-1.jpg   Oil Pump "CHECK BALL" is Weeping Oil-check-ball-2.jpg   Oil Pump "CHECK BALL" is Weeping Oil-check-ball-3.jpg   Oil Pump "CHECK BALL" is Weeping Oil-check-ball-4.jpg   Oil Pump "CHECK BALL" is Weeping Oil-check-ball-5.jpg
Old Aug 25, 2011 | 04:34 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
When does the oil come out the breather? On startup? Every time?
Or does it blow out the breather all the time the engine is running?
SCHOONER
11
Nov 7, 2012 10:06 AM
SCHOONER
Oct 4, 2011 06:05 PM
SCHOONER
Exhaust System Topics
11
Aug 22, 2011 11:03 AM
SCHOONER
Nov 28, 2010 10:57 AM
agapsdiver
Feb 23, 2007 04:05 PM
