Oil Archive (no new posts) An archive of oil related questions and comments.
View Poll Results: A poll
HD primary oil #99887-84 (old style)
12.18%
Syn 3
14.02%
Amsoil
21.83%
Bel ray
2.51%
Rev tech
1.01%
Dyna cycle
0.22%
Redline
12.06%
Mobil 1
21.48%
Doesn't matter
3.08%
other
11.63%
Voters: 5066. You may not vote on this poll
What Primary Oil is your Choice
Old Sep 15, 2016 | 04:48 PM
  #501
Oddball211's Avatar
Oddball211
Stage II
How long are you going between oil changes with amsoil 20/50, I'm going 10,000...
Old Sep 16, 2016 | 08:20 AM
  #502
Tucker99's Avatar
Tucker99
What is that terrible smell when changing the old oil. Is that the commutator coils?
Old Sep 16, 2016 | 08:41 AM
  #503
xcbullet's Avatar
xcbullet
They say when it stinks the stator is going bad
Old Oct 17, 2016 | 04:53 PM
  #504
rocket23's Avatar
rocket23
really would like to know what I have for a compensator before I change the oil.....if it is oem I'd change it out......se or baker then I'd just change the oil,......no issue's as of yet.
I went to a synthetic same compensator, I have wrench lined up to change the comp to an se and use the warranty that I have.
Old Oct 19, 2016 | 12:31 AM
  #505
Anthony Paul's Avatar
Anthony Paul
Atf III + B&M Trick shift = Like a Sewing Machine
Old Oct 19, 2016 | 12:43 PM
  #506
rocket23's Avatar
rocket23
THAT's what I heard today!!
Old Oct 22, 2016 | 06:29 AM
  #507
xcbullet's Avatar
xcbullet
I really liked the amsoil primary but found all it takes is 25% amsoil OE trans fluid mixed with it and she shifts like a dream. As good as running straight trans for shifting but feel it has better protection this way.might try using a mix of less atf to see how low it can go and still shift good. Sure can go lower % in heat as this is cool weather now @ 50°f.
Old Jan 16, 2017 | 07:15 PM
  #508
Jcook77's Avatar
Jcook77
6th Gear
Either i have missed a post or im the first to ask about it, but has anybody used amsoils primary and trans oils yet? Ive always uses 20w50 in all 3 holes. Wondering if its worth the money to make a switch.
Old Jan 16, 2017 | 08:01 PM
  #509
deadbroke's Avatar
deadbroke
I switched to Amsoil on my '08 Roadking. I used their specific trans oil and their Primary oil. Honestly I've noticed no improvement.
Old Jan 16, 2017 | 08:05 PM
  #510
Jcook77's Avatar
Jcook77
6th Gear
Well id like to get the trans to shift a little more smooth. I also thought about trying there sever gear 75 110
