I like oil mineral 20w50 JasoMa2 (lubrax essencial 4t)
the problem with a 50 w is the thickness...it has an adverse effect on cold starts....But I live where it's cold so it may not be the case where you are......by adverse I mean it relies on the chain to throw the oil in the primary case and an oil behaving like syrup can't be good.....jmho.
Yes, here brazil very hot, my byke starts rapid. but my big question is: Mineral X sinthetic ??? kkkkkkk.....
My new primary oil, 30 weight is perfect and at this price can change it a lot. Put this in truck 4x4 transfer case too. I can pick it up about 5 miles from my house, any 30 works good even 10-30 from the cheapest to amsoil. I have no problems with any of them slipping on my 150,000 mile clutch. some might have problems with friction modifiers in higher horse power bikes. that oil above I would think would be great any primary, not to thin or thick just right.
clicked the link.......first thing that I thought of was huh, ''not suitable as a motor oil''........a lot is made up for primary oils, not being under pressure ,no excessive heat...pretty much just a ''bath ''oil...that being said , weasel **** would probably suffice in a pinch.....joking of course , not belittling the farm oil in any way.
I would think you would want a decent oil in there. Lots of friction with the bearings and the comp. banging around in there.
it would be a catastrophe if the primary had none, but really, the best oil is the one that can help you find neutral AND lube everything else. ....redline does this nicely.
Was hoping to find some constructive advice... I've decided to switch from Syn3 in all three holes on my Stage II bikes. I'm looking at these choices, in this order, for the primary:
Bel-Ray Primary Chaincase Lube
Spectro Heavy Duty Primary Chaincase Oil
Red Line V-Twin Primary Case Oil
AmsOil Synthetic V-Twin Primary Fluid
The Bel-Ray was what I was recommended by the two FuelMoto techs I spoke with.
