Oil Archive (no new posts) An archive of oil related questions and comments.
81 shovel oil leaks
Old Mar 19, 2007 | 07:57 PM
Screw's Avatar
Screw
6th Gear
Default 81 shovel oil leaks
On my 81 superglide, i am suddenly developing oil leaks, EVERYWHERE, oil pump, rocker boxes, primary case, EVERYWHERE litteraly overnight.
This bike never leaked a drop, then one day, Friggin oil everywhere.
rebuilt the oil pump
replpaced all oil lines
replaced all seals on oil tubes to rocker boxes
everyone's tellin me it must be building pressure in the case.
Can't see how.
cleaned the tappett screen.
motor runs unbelievably strong, with NO oil out of the exhaust.
tests good for compression
anyone been through this?? have any ideas??
maybe sumthin i coulda missed??
Old Mar 19, 2007 | 08:18 PM
cj_slowdown's Avatar
cj_slowdown
Default RE: 81 shovel oil leaks
ORIGINAL: Screw
Can't see how.
Screw,
I have a shovel, thisis anarea is for all oil subjects, but I would also post this on the shovel section, main page second section down, under Harley Davidson Motorcycles, Sub-forums "Shovelheads"
just a thought
cj
Old Mar 19, 2007 | 08:20 PM
Screw's Avatar
Screw
6th Gear
Ya know, ,i did, but thought it was in the wrong spot, so i moved here.
I'll give it a little, c what happens.
Old Mar 24, 2007 | 07:34 PM
Screw's Avatar
Screw
6th Gear
To all who viewed: i might have found the problem. oil pump check ball stuck, gear case filled up w' oil, and was gettin' slung everywhere it wasn't supposed to, including blocking the vents.
I'll letcha all know if this fixes it!!
(i was also gettin the dreaded oil outa the air filter, so we'll see.)
Old Mar 24, 2007 | 07:39 PM
ChiefGator's Avatar
ChiefGator
I was wondering if you had it figured out. Thanx for the update. Let us know if that did the trick.
('82 Shovel here)
Old Mar 25, 2007 | 02:25 AM
Screw's Avatar
Screw
6th Gear
we'll do. gonna take me a week or 2, but i'll letcha know
justgliding99
Aug 15, 2018 07:24 PM
baldy59
Shovelhead
Jun 24, 2017 12:18 PM
stang32903
Feb 17, 2009 09:15 AM
bobsemp
Ironhead
Apr 6, 2008 04:37 AM
dwn1383
Panhead
14
Mar 24, 2008 03:03 PM
