Oil Archive (no new posts) An archive of oil related questions and comments.
Oil Change Question
Old Sep 7, 2014 | 07:44 AM
1Blackhatch's Avatar
1Blackhatch
Default Oil Change Question
The filter on my bike is mounted transverse. Not uncommon even in automotive applications.
My questions is that because you can get a full fill rate on the filter prior to installation, does anyone crank their engine over prior to full ignition and how would that be done on these.
In automotive applications, it is easy to just pull the fuel pump relay prior to changing the oil and let the car die. After oil change, crank the car over several times to get full circulation and pressurization in the system.
Is this even an option on Harleys?
Old Sep 7, 2014 | 07:49 AM
Smokey Stover's Avatar
Smokey Stover
I just screw it on,Fill it up,Ride,recheck level later when hot,Per Manual.
Old Sep 7, 2014 | 12:06 PM
jpowell490's Avatar
jpowell490
No it is not, don't do that. These are not wet sump systems like your car.
Old Sep 7, 2014 | 08:38 PM
1Blackhatch
Totally blanked on that part. You are 100% correct.
Thanks for pointing that out.
Old Sep 8, 2014 | 07:38 PM
jpowell490's Avatar
jpowell490
Anytime! Welcome to the forums.
Old Oct 2, 2014 | 08:30 AM
EasternSP's Avatar
EasternSP
You might consider this. It's made by Moore Sensible. Web site: http://www.mooresensible.com/ costs $199.00. Takes about 30 minuets to install.
I have the H-D oil cooler on the bike to but that doesn't interfere with it. The cooler adapter mounts on the passenger foot peg mounting hardware. The foot peg goes back on after you install the adapter. The oil filter can be precharged before installing it. It's up high enough so it doesn't drag in hard cornering.
Old Oct 2, 2014 | 02:44 PM
1Blackhatch
That is slick!
Love it. Thanks for the link.
Old Dec 28, 2014 | 09:57 AM
1Blackhatch
Does anyone mount this filter to the front frame spar?
Old Jan 4, 2015 | 10:25 AM
Roses's Avatar
Roses
Not to start a debate, but all big twin Harleys are now wet sump except for the "B" motor softails. If I am incorrect so be it, but a dry sump system has to have a separate oil tank. That is the way the softails are set up as was my old "75" Sporty. However, my dyna has an oil pan under the motor and you check the oil at the motor not at a separate oil tank like the softails. I used to have to change the oil by draining the oil tank, now I unscrew a drain plug in the bottom of the engine, just like my car.
Old Jan 6, 2015 | 03:19 PM
1Blackhatch
That is interesting.
So are the newer ones wet sump?
Doesn't seem like there is a pan/reservoir deep enough for the pick up and sump.
