Spark Advance Tab
I am building a 59 Panhead, The case that i have has the right numbers on it, but it is missing the spark advance tab in front of the distributor on the right case. At first i thought it didn't come with the tab because it had automatic advance, but i am seeing that 1961 is when they switched to automatic advance. i just want to know if all, some, or none of the Panheads form 1959 had automatic advance.
Thanks
Thanks
Not sure where you got your information but it is incorrect.
Manual advance single point timers were used on 1936-1960 OHV models. Manual advance dual point timers were used on OHV models from 1961-1964. 1965 OHV models used the auto advance timers (which was also the last year for the Panhead motors).
If your serial number is good and belly numbers match, indicating you've got a good set of original cases, then the mounting boss has been cut off. Someone could have run a magneto or an auto advance breaker and cut it off for a "cleaner look" back in the 60's or 70's.
Chum mins,
I ran into the same issue on my pan head . I think someone in the past had cut off the boss where the manual advance cable mounted. I fabricated a bracket that mounted to one of the timer hold down bolts and up and over the case. Looks like it belongs and only the experts will know it is not original.
Mine was shaved years ago by the previous owner for a Mag...no doubt that's probably what you've got.
Very common back in the day when these motors were a dime a dozen and super cheap...it was all good to chop.
Whole different world now.
BobRR
Jul 15, 2019 03:26 PM
Curated Content Editor
Mar 14, 2017 07:39 PM
