lifter blocks
Old Jul 23, 2007 | 07:12 PM
wreck74's Avatar
wreck74
Default lifter blocks
I have a 59 pan with solid lifters and 1948-49 aluminum lifter blocks, (no oil passage in the blocksfor the hyd) the rocker arms are in the shop getting pined, .030" oil passage to the top of the pushrod, where will the lifters get their oil ? do i need to drill them or replace them with later model blocks with oil passages ? thanks for any help.
Old Jul 23, 2007 | 07:42 PM
panz4ever's Avatar
panz4ever
Default RE: lifter blocks
wreck, you only need the later style lifter blocks if yur gonna run hydraulic lifters. But if you areI wouldn't drill the aluminum ones, buy some later ones and save the originals.
Old Jul 24, 2007 | 08:19 AM
crampfan's Avatar
crampfan
^^^^ like he said.
Old Jul 24, 2007 | 03:42 PM
wreck74's Avatar
wreck74
so it'll be allright to run solids with the 48-49 lifter blocks ? what i'm wandering is will the lifters get enough oil with the rocker arms pined ?
Old Jul 25, 2007 | 08:24 AM
crampfan's Avatar
crampfan
The timed breather oils everything in the timing area very well. you will not have any issues at all. I have been running this way for over 100k miles.
Old Jul 25, 2007 | 10:55 AM
wreck74's Avatar
wreck74
right on, thanks for the info. i'll let ya allknow how it turns out.
EL in NH
Jan 23, 2018 09:40 PM
Gordon61
Engine Mechanical Topics
Mar 17, 2017 10:44 AM
dwn1383
Panhead
14
Mar 24, 2008 03:03 PM
2005UltraNC
Exhaust System Topics
Jun 17, 2007 03:24 PM
rah002
Oil Archive (no new posts)
Feb 6, 2007 02:58 AM
